grain drill values?
mud
03-03-2005 05:33:38
Finally going to bite and find a reasonable grain drill. Tired of renting the Coop's drill.
Small farm. Don't need nothing fancy, just functional. Any suggestions?
riverbend
03-03-2005 11:28:24
 Re: grain drill values? in reply to mud, 03-03-2005 05:33:38
I have a couple old 10' grain drills. One was $3 and the other was $20. Between the two of them, there were enough parts to make one good one. They won't do no-till, but they do work.
Hay Dr
03-03-2005 07:02:54
third party image
We offer Haybuster Coulters and disc below the prices that Haybuster dealers can purchase these wear parts.
Tim(nj)
03-03-2005 09:38:11
 Re: grain drill values? in reply to Hay Dr, 03-03-2005 07:02:54
Around here, a Haybuster 107 is a cheap drill at auction because it has such a bad reputation for the disks not lasting many acres and bearings constantly failing in the openers. Are these assemblies more durable than original?
Hay DR
03-03-2005 14:39:25
 Re: grain drill values? in reply to Tim(nj), 03-03-2005 09:38:11
We rent Haybuster drills and we are in clay and rock country so these coulters get a workout. We change out the OEM disc & coulters that come on the drills at 1000-1200 acres and the CCM coulters usually get changed out at 2000-2500 acres and sold as 1 or 2 replacements for the retail trade farmers needing one maybe where they broke one on a rock. Our neighbor has over 3600 acres on his set of CCM coulters and disc. We use Boron steel for extended wear. Our bearings and bearing cages will usually last 5000+ acres. Our coulters are 4.5 mm thick. The OEM coulters are 4 mm thick. Our disc is 3.5 mm and the OEM disc is 2.5 mm thick.
Tim(nj)
03-03-2005 19:35:17
 Re: grain drill values? in reply to Hay DR, 03-03-2005 14:39:25
Ah, this is useful info indeed . . . . perhaps I will take a second look at one of those "no good" Haybuster drills . . . .
Hay DR
03-03-2005 14:38:15
TomTX
03-03-2005 05:44:25
Need more details about your planned usage. No acres? types of seeds? need small grass seeds box? how much reconditioning work do you want to do?
mud
03-03-2005 06:37:04
 Re: grain drill values? in reply to TomTX, 03-03-2005 05:44:25
Drill orchard grass and red clover over about 40 acres. I'd like one that is field ready.
What do you recommend?
thurlow
03-03-2005 09:15:15
 Re: grain drill values? in reply to mud, 03-03-2005 06:37:04
You didn't say if this was into a prepared seedbed or no-til; was gonna suggest a Deere 8200-8300 if it's a prepared seedbed (and you can find one with small seed attachment). Different prices for different localities, but I would guess $1000-2000, depending on condition and attachments..... ...
mud
03-03-2005 11:31:49
 Re: grain drill values? in reply to thurlow, 03-03-2005 09:15:15
Prepared seedbed. Rotavated. Will pull Brillion packer behind 'vator.
JMS/MN
03-04-2005 14:29:42
 Re: grain drill values? in reply to mud, 03-03-2005 11:31:49
As long as you have a decently prepared seedbed, any single or double disk drill should do, with a tooth or coil drag, or packer behind. Should be able to find a good 10-12 footer for a couple hundred bucks.
