trailer plow??----------help!
maddog
02-28-2005 04:05:18
I would like to buy a 5-6 bottom trailer plow. 14" or 16" does not need to be late model, but does need to be able to go to the feild. I have owned oliver semi mounts, heard they were the tops in plows. What does anyone else think?
CEB
03-02-2005 13:38:28
 Re: trailer plow??----------help! in reply to maddog, 02-28-2005 04:05:18
I have a JD F-145H semi-mount. It really works nice. I also have a JD trailer plow, it works good also. Between the two, I prefer the semi- mount. Its easier to turn on the ends and it has a lot more clearance. The old trailer plow plugs up pretty easy if you have very much trash on the surface.
720D
03-01-2005 06:30:56
My father inlaw has a IH 5x14 trailer plow that is in good shape and always been shedded that is in good shape and is ready to go to the feild.
cat
03-01-2005 18:41:11
 Re: trailer plow??----------help! in reply to 720D, 03-01-2005 06:30:56
Is it in good shape?
720D
03-02-2005 05:13:32
 Re: trailer plow??----------help! in reply to cat, 03-01-2005 18:41:11
Its in excellent shape. Asking 375.00 OBO
farmertee
02-28-2005 14:02:21
I have a White trailer plow. It resembles the Oliver 4340. I also have a set of 151 Ford semi-mounts w/o spring reset. They were made by the Pittsburgh Plow Co. so they are basically the same as Oliver points and shins are interchangeable. I recently bought a set of White 508 spring resets. They are the cadillac of moldboard plows in my opinion. Of course I know a guy that swears by the IH 720 auto resets. It all depends what your used to I guess I have plowed with nothing other than Oliver or White products. If you have enough hp than I would go for a 4 bottom semi-mount like 80 hp. I personally like the semi-mounts better than a trailer plow and I have both.
farmertee
02-28-2005 13:52:16
