What is it called?
Ultradog MN
02-27-2005 11:14:26
I uploaded a picture to the Help Identify Section this site. It's a digger that I've been working on here. Had it sand blasted then primed and painted it. The Tag says Ford Model 19-286.
It was red but I made it blue to match my Ford tractor.
I bought it to scratch up some rocky soil that wont accept a plow and then hand broadcast some rye or something for a wildlife plot.
I'm just wondering what the correct name for it is.
Thanks
Jerry
Ultradog
02-28-2005 04:55:38
 Re: What is it called? in reply to Ultradog MN, 02-27-2005 11:14:26
I figured it was some kind of cultivator. Just thought that a true cultivator had the spring shanks and the guards for weeding rows of corn etc.
Marlowe, I had to replace 2 points. Found them at Fleet Farm. About $3.50 each. They were a little too long so I torched about 1 1/2" off the point.
They had 2 styles there. One had more curve. These fit pretty good. The label on them said they were quackers.
Thank you all
Jerry
jhill
03-01-2005 12:43:14
 Re: What is it called? in reply to Ultradog, 02-28-2005 04:55:38
Ultradog you are thinkig of a row crop cultivator which is different than a field cultivator.
marlowe
02-28-2005 13:25:59
i found the same ones at fleet but they are shaped a little differnt then oem
Jerry D in NC
02-27-2005 23:35:49
Jerry,
Here in NC we would call it a 7 shank tiller. That was the name that all the old farmers used. A field cultivator "Here" has more shanks closer together with a soil leveler behind the shanks to leave the field in ready to go condition. If needed I will be happy to take a picture of what we currently calla field cultivator and post.
RJ-AZ
02-27-2005 20:06:45
That appears to be a Dearborn field cultivator. dad still has one and he used either spikes or shovels depending on what we were doing with it. he would remove two of the shanks for culivating the Tater patch.
Chris Brown
02-27-2005 16:31:06
We had one when I was a kid,Grandpa only called it the scratcher. Ours was identical to yours. We used it as a field cultivator in south Missouri"s rocky ground.
Tim(nj)
02-27-2005 14:27:07
I think you"ve actually got two put together to give more clearance between shanks. All I"ve ever seen have the usual double Ferguson/Dearborn multi-hole angle-iron tool bar.
Ferguson and Dearborn both called these tillers in sales literature. This is before rotavation machines were common. Call them tillers now and it confuses people, because they"re thinking rototiller. Quack digger is a term that I"ve only heard come from the upper midwest. Here in the Mid-Atlantic it would be called a field cultivator by most people.
paul
02-27-2005 15:12:25
 Re: What is it called? in reply to Tim(nj), 02-27-2005 14:27:07
A quack digger would typically have very wide duck-foot shovels, not points.
--->Paul
marlowe
02-27-2005 14:03:11
P.S. did you replace any points??if so where did you find them ?? can't find any with the right curve
marlowe
02-27-2005 13:59:07
sorry that is not a field cultivator it's a ford quack digger .deerborn and ferguson also made them they have a coil spring or two as a trip meck. not the spring type as on the cultivator
jhill
02-27-2005 19:35:58
 Re: What is it called? in reply to marlowe , 02-27-2005 13:59:07
Sorry but in the Ford sales literature it is called a field cultivator.
jhill
02-27-2005 11:53:36
It is called a field cultivator. Should work good for what you want to do.
sammy the RED
02-27-2005 11:50:58
Looks like a cultivator to me.
Dave H (MI)
02-27-2005 16:08:39
 Re: What is it called? in reply to sammy the RED, 02-27-2005 11:50:58
Did ya get out to the farm this weekend? Supposed to snow again tomorrow.
sammy the RED
02-27-2005 21:44:31
 Re: What is it called? in reply to Dave H (MI), 02-27-2005 16:08:39
Went danceing instead !
Dave H (MI)
02-28-2005 07:25:57
 Re: What is it called? in reply to sammy the RED, 02-27-2005 21:44:31
Well lucky you! Give me a holler on my email when you get a chance and let me know what's up.
I am thinking I want to do this.
sammy the RED
02-28-2005 11:48:05
 Re: What is it called? in reply to Dave H (MI), 02-28-2005 07:25:57
OK, I will try and get out there this week sometime.
