John Deere Van Brunt Model B grain drill
Ardie
02-26-2005 08:23:04
I have a Van Brunt Model B grain drill. When I slide the lever on the outside of the box to adjust the grain output, one of the seals next to the grain rollers slides with it. I believe these seals are to keep the grain inside the grain rollers???? These are in the bottom of the box. What can I do to keep this seal in place?
Thanks in advance
Ardie
TomTX
02-26-2005 12:24:56
 Re: John Deere Van Brunt Model B grain drill in reply to Ardie, 02-26-2005 08:23:04
I have a JD/VanBrunt Model B, but can't figure out what part you are asking about. You can get both an Operator Manual, and a Parts Manual throught JD dealer. I used both of my manuals extensively when I rebuilt everything.
Ardie
02-26-2005 12:56:32
 Re: John Deere Van Brunt Model B grain drill in reply to TomTX, 02-26-2005 12:24:56
These are in the bottom of the grain box, one for each row, they feed the grain into the grain tubes. When you slide these back and forth for adjustment the seal slides with it, it it only one seal that is sliding out of position.
Thanks Ardie
