Converting moldboard plow into ripper
Drillbit
02-23-2005 13:44:51
I was thinking that you take all of the parts off the plow and leave the shanks in place. Then take some chisel plow points and put them on there somehow. Have any of you ever done this or ever heard of anybody doing this before. I think it could be done. You could get a plow pretty cheap since many people don't use them anymore. Thanks.
Leroy
02-25-2005 03:44:54
 Re: Converting moldboard plow into ripper in reply to Drillbit, 02-23-2005 13:44:51
Used to be an aftermarket company made conversion for older pultype plows just when the chisel plows were coming into use
sam in mo
02-24-2005 06:34:38
I have a old JD plow that has points on it. It is a solid beam plow with iron wheels.I have never used it so I dont know how it will work.
Tim(nj)
02-24-2005 05:54:26
Back in the late "80s, Deere sold a kit to put rippers on the 2000-series plows in place of the plow frog assemblies. If you do this, you should make a replaceable wear strip to put on the front of the beams above the points. One thing to think about, ripping goes deeper than the plow normally goes, so beware of rocks stuck down in the hardpan layer. For my ground, an auto-reset plow would be my choice for the conversion.
J. Schwiebert
02-23-2005 18:05:09
I do not know what brand of plow you have but in the 60's Oliver had hardpan rippers that attached to the beam and they were to tear up the next couple of inches. Most people who purchased them said they did the job but they all said in this clay it was like you just added another bottom especially if you added two instead of one.
Nebraska Cowman
02-23-2005 17:05:07
I've got an old horsedrawn 2 row lister with shanks on it. It is about all my Farmall M wants to pull. So I guess your idea would work.
Drillbit
02-24-2005 12:17:56
 Re: Converting moldboard plow into ripper in reply to Nebraska Cowman, 02-23-2005 17:05:07
I think a 2 shank would be all an IH 484 would want. Most of our land is loamy so it wouldn't be to bad. Then I could have some power to spare
