Semi mounted plow
Dave H (MI)
02-21-2005 11:49:42
Can someone tell me how these attach to the tractor? My semi mounted mowers bolt right to the drawbar. I have pics of a semi mounted plow that is for sale and it looks like it has hook ups for three point lift arms but not the top link. Hard to tell from the pics. How do semi mounted plows attach?
Hugh MacKay
02-21-2005 15:46:52
 Re: Semi mounted plow in reply to Dave H (MI), 02-21-2005 11:49:42
Dave: Semi mounts are basically a cross between a trailer and mounted plow. Your hitch lifts front of plow while a tail wheel lifts the rear. They are a two lever function, going into as well as out of soil. In both cases you activate your hitch first then the remote valve for tail wheel. As Wayne said the early ones just had a caster wheel behind, while later ones had the steerable tail wheel. The models with steerable tail wheels also pivoted side ways at tractor hitch, to allow turning. My 1066 on 5x16 semi mount could leave headlands as short as 12' as you can start to turn as you raise or lower plow. They have a ty rod run from tractor hitch to tail wheel.
My plow was an IH 510 which is steerable and behind any of 06, 56, 66 or 86 series tractors. Those tractors would complete the hitch function before remote valve functioned thus the plow entered and exited soil just like a trailer plow. When I bought my plow, my dad was a dyed in the wool trailer plow man. An older neighbor who also did a lot of tractor work for me was probably as firm on the trailer plow issue as my dad. When dealer delivered plow, he hitched it to 1066 and I asked him to leave manual in cab. Tractor was some distance from farmstead. My dad and friend knew what I wanted plowed. I also knew, that new plows are not adjusted very well. I knew those two would take the time to do it right. Three days later I get a phone call from them, "We need diesel fuel." I said, "there is about 100 gallons in tank where you are." "Oh". was the responce, "We have that all burnt and need more." I always had a tank on pickup for fueling tractors in field, so went up. They plowed close to 300 acres that fall and I got to do 5 acres. I'm not sure which they liked the best; semi mount plow or the cab. They told me I had a lifetime to plow in a cab, they had spent 40 years freezing doing Nov. plowing. I noticed, the next spring my dad took 1066 and 5x16 semi mount to plow his garden, 130 with 2x12 fast hitch had always worked in the past. This garden was afterall, the retirement garden after family was all grown and away from home. New toys do wonderful things to old men.
ShepFL
02-22-2005 19:23:25
 Re: Semi mounted plow in reply to Hugh MacKay, 02-21-2005 15:46:52
Great story Hugh! I always enjoy reading your posts. I must say that my favorite tractor "chore" is plowing. I cannot afford no-till so I still use conventional tillage equipment in my efforts. Over time I have become rather good at it if I may be so bold.
Thanks for the story!
Regards
720D
02-22-2005 14:17:03
Hugh what size trailer plow are you looking for.
Hugh MacKay
02-22-2005 15:55:17
 Re: Semi mounted plow in reply to 720D, 02-22-2005 14:17:03
720D: You must have confused me with someone else. I am not looking for a plow. Dave is the guy looking for a trailer plow. There is also someone else looking maybe even two on these plow threads and over on Tractor Talk.
thurlow
02-21-2005 19:13:39
Hugh, great story; I can certainly relate. When I was (much) younger, I despised running a disk, do-all, harrow, field cultivator, etc; something to be done 2-6 times for each field. But a breaking plow..... .different story; once over and you're done for the year. Only had open station tractors in those years; we had a 5 bottom and a 6 bottom JD 145H; used 'em for years behind 4020s; eventually had 4620s and 1066s. Nothing like watching those ribbons roll (and smelling that soil) in the early spring. Ah..... .the good ole days.
Hugh MacKay
02-21-2005 19:36:48
 Re: Semi mounted plow in reply to thurlow, 02-21-2005 19:13:39
thurlow: Don't get us all carried away here now, plowing was always my favourite tractor job. Man you start talking about those ribbons of soil, and between diesel and soil smells, more exciting than the first time some sweet 16 year old damsel sat on your knee at the Sat. night dance.
Then again maybe there is more comparison than one initially thinks. My dad was asked once what he thought of a tractor mounted roto tiller at a demonstration. He replied, "That soil is much like any female, if you want it to reproduce you don't beat the crap out of her, you roll her over nice and gently as does a moldboard plow."
I better be careful here or I will be giving that guy Roger Wells a new title for a book.
MichaelNEIowa
02-21-2005 18:51:41
Hugh, you always have the best stories. One of the reasons I love this site.
Hugh MacKay
02-21-2005 19:40:17
 Re: Semi mounted plow in reply to MichaelNEIowa, 02-21-2005 18:51:41
Michael: Read my responce to thurlow. Then wait for my new book,"sex and plowing"
buickanddeere
02-21-2005 22:18:31
 Re: Semi mounted plow in reply to Hugh MacKay, 02-21-2005 19:40:17
Or how about the title "sex and planting seed"?
Hugh MacKay
02-22-2005 07:57:38
 Re: Semi mounted plow in reply to buickanddeere, 02-21-2005 22:18:31
Your post reminded me of an old widower in my home town. His son got married and 7 months later the first addition arrived. Old guy cornered the attending doc a few days later at the local gas station with, " Say doc, shouldn't that have taken 9 months." Doc. replied' "Lack of experience they didn't get the seed deep enough." Doc when on his way and didn't give the old guy chance to respond. Old guy was probably thinking of rewriting his will.
Dave H (MI)
02-22-2005 12:04:10
 Re: Semi mounted plow in reply to Hugh MacKay, 02-22-2005 07:57:38
Jeez Hugh...after reading the responses I had to go back and re-read the question to see what exactly it was that I asked! lol
Hugh MacKay
02-22-2005 15:49:08
 Re: Semi mounted plow in reply to Dave H (MI), 02-22-2005 12:04:10
Dave: As I said earlier somewhere in this thread and I've said it many times before, plowing is one of those jobs I never got tired of with a tractor. It's never mattered whether it was my Farmall 130 with fast hitch plow, or 1066 with 5 bottom semi mount. To see those nice straight furrows rolling behind you. I always tried to lay out the field so the actual land plane smoothness improved. You can actually do that with the moldboard plow.
Once had a young 15 year old plowing with 656 and 5 bottom semi mount. His father before him had been a champion plowman. The father was actually the guy I mentioned sharing plowing with my dad that first year with 1066. Anyway this was the young lads first plowing and he did make a few screw ups. I told him he was a bit of an embarassment to the family name. I knew he would go home and tell his father. Dad showed up with him next day and the young lad did learn to plow.
You see guys like thurlow and I can get carried away with our plowing. Everyone who has anything to do with tractors should treat himself to plowing.
thurlow
02-22-2005 13:38:13
Well, Dave, let me apologize for all of us..... I guess you meant your questions in the VERY literal sense and we had a flight of fancy; some of us ( I guess) read different connotations in the words "hooker-upper", "attachments", "sale" (things you might buy down in the red-light district), etc. Trust me, when you reach a certain age, the consideration of "things" is more fun that the accomplishment of "such". Confused now?????
Dave H (MI)
02-22-2005 14:24:19
 Re: Semi mounted plow in reply to thurlow, 02-22-2005 13:38:13
CONF-used and AM-used as long as I am not AB-used....which reminds me, I have to go over to the IH forum and see how bad they are AB-using me for defending the distinguished ones honor.
buickanddeere
02-21-2005 22:16:57
Dave H (MI)
02-21-2005 17:46:03
Thank you gentlemen! That clears that up nicely.
The farmall doesn't have a 3 pt and I am quite fond of it the way it is, so I will pass on this semi mounted plow and continue looking for a trailer plow. Kind of like the way they look behind the older tractors anyway. Thanks again!
Dave
Wayne in Pa
02-21-2005 13:43:49
Yes the semi mounted plows attach to the lift arms of 3point hitch. That is what carries the front of the plow the back has a hydraulic cylinder to raise and lower. Some of the first models had castered tail wheels the later models had stearable tail wheels.
