NH 256 rake
farmertee
02-19-2005 13:38:01
I bought a 256 at auction to upgrade over my NH 56 rake. However I noticed when I back up with the 256 the teeth want to also go backwards. I was wondering if this is normal on this model or not. I never had that problem with the 56 it just clicked until you started to drive forward. Any ideas or help would be appreciated.
Steve from New Holland
02-21-2005 04:40:38
 Re: NH 256 rake in reply to farmertee, 02-19-2005 13:38:01
It should click when backing up. I would be interested in seeing if someone accidently installed one of the dogs in the wrong direction. This is possible to do. Steve
Nebraska Cowman
02-19-2005 17:45:32
probably just stuck, reminds me of a pickup a man traded to the dealer, he said "it is wore out, except for the grease zerks, they've never been used."
Ron in AR
02-19-2005 15:39:11
I have two 256s and they both run neutral when backing up (they click). Something wrong somewhere.
RickB
02-19-2005 14:43:11
Jack up each wheel and see if the overrunning clutch in each hub is functioning. It should work the same as your 56.
Joel Harman
02-19-2005 14:35:55
No clicking when backing? sounds like bad dogs in hubs.
Caveat - I do not know this rake, this is just general knowledge about ground drive equipment
