7000 john deere 6 r0w no till planter
sugar bear g
02-19-2005 12:48:57
in real good shape with monitor on a sale what is it worth thank you.
Indydirtfarmer
02-19-2005 13:13:20
 Re: 7000 john deere 6 r0w no till planter in reply to sugar bear g , 02-19-2005 12:48:57
Liquid or dry fertilizer? Pesticde boxes? Row markers? Deere or aftermarket coulters? Row width? The list goes on.....
They will sell from a low of around $1000 to as much as $4000. I've seen rough ones sell for a couple hundred bucks.
sugar bear g
02-19-2005 14:13:50
 Re: 7000 john deere 6 r0w no till planter in reply to Indydirtfarmer, 02-19-2005 13:13:20
dry fert no pest has row markers deere coulters 30 inch rows and has not been used in ten years but has been kept in dry shed my question is did that hurt the planter thanks.
RickB
02-19-2005 14:44:41
 Re: 7000 john deere 6 r0w no till planter in reply to sugar bear g , 02-19-2005 14:13:50
Didn't help it. Will need new seed belts in the units. That will be a good excuse to look at the fingerwheels.
John e.c.MI
02-20-2005 08:03:09
 Re: 7000 john deere 6 r0w no till planter in reply to RickB, 02-19-2005 14:44:41
For a small anout of $$$ put new seed belts and brushes in it. You can have the seed meters run on a test stand for $15-20/row to fine tune them. I would not let the long storage period be a factor if the planter is in good shape.
JMS/MN
02-20-2005 19:37:07
 Re: 7000 john deere 6 r0w no till planter in reply to John e.c.MI, 02-20-2005 08:03:09
Seed belts are about 8 bucks per row, backing plates are about 21- look for corrosion or wear that can scratch the seed. Brushes are a buck or two, pickup fingers about the same. Pretty reasonable to rebuild the units.
