Carolyn Sounds like you have most of the bases covered. Here are a few more thoughts. First, how is the hay? is it dry enough? Does the hay bunch up on top of the pickup, in front of the starting roller? Does any hay wrap around the starting roller? Those old Vermeers had a "Feature" that it would not let you bale hay unless it was fit to be baled. Second thing to look at. What kind of teeth are in the pickup? Spring or rubber mounted. Genuine Vermeer rubber teeth work MUCH better than aftermarket ones. The aftermarket ones flex back and do not force the hay in the chamber to start the bale. Final thing to consider. How may bars in the pickup. Our 605F had 4 bars and was very hard to get a bale started. The 605 Super F(rest its soul) had 6 bars and would start under almost any condition. In native hay it was nessecary with the F to start a bale on a ridge in fine leafy hay and then move into the sloughs to finish. This was slow, but much quicker than continually unplugging the baler. No matter how carefull I was with the Super F I seemed to plug at least once daily so I carried a pair of gloves and goggles with me all the time. Good luck!
John
