JD Baler 530
Jeff Phillips
02-16-2005 13:32:20
Can the 530 be converted to the twin arms out of a JD535. Also, what do I do about the second twine box and the speed of travel in the arms? Thank you!
Tx Jim
02-17-2005 04:15:53
 Re: JD Baler 530 in reply to Jeff Phillips, 02-16-2005 13:32:20
Jeff,I saw a 530 that had been converted to twin tie arms.The twine box was across the front above the door that one has to raise to adjust hyd. pressure.I don"t know if the control valve for twine speed had to be exchanged for 535 valve.Have you thought about trading for a 535 baler/pushbar?No more need to back up to dump.Tx Jim
