Used tires at auctions.
Dave H (MI)
02-15-2005 16:43:41
Most times I go to the auctions there seems to be a pile of tires that look good but...? If I find an implement tire at an auction, how do I tell if it is any good? Sounds simple enough to say that if it has tread it's fine, but what about the seal around the wheel?
riverbend
02-15-2005 19:38:24
 Re: Used tires at auctions. in reply to Dave H (MI), 02-15-2005 16:43:41
You can look at the bead of a tubeless tire and see if it will seal. If it is ripped across the inside surface it will have a hard time sealing. If you are using tubes, it is not a problem.
Look at the side wall of the tire for weather checks. If you can bend the side wall you will be able to see them better. Avoid any tire where you can see the cords.
Look inside the tire. There should not be any cracks in the rubber. Stay away from tires with large patches on the tread and any patch near the side wall. Carefully feel around the inside of the tire for nails, etc. If it is a belted tire, rub your hand around the tread. It should be smooth. Bumps or twists indicate a broken belt. If you get stabbed by a wire, it has a bad belt.
Some car and truck take offs might be okay. Implement tires usually get replaced for a reason. No sense paying for a junk tire.
paul
02-15-2005 19:32:06
I haven't mounted a used tire without a tube in 20 years. Seal is great with a tube.
Look inside the tire for cuts or cords showing, that is common on otherwise 'good' used tires.
--->Paul
