JD-44 H Plow
d wood
02-15-2005 15:50:39
How do I determine whether I have a 14 inch or 16 inch plow?
55 50
02-18-2005 15:10:49
 Re: JD-44 H Plow in reply to d wood, 02-15-2005 15:50:39
RiVerbend and Leroy gave good info. I have a 44-H and it is marked with a 14-16 decal on a front frame piece and the two arms to the bottoms go out so mine is set to 16 inches. It can be measured also by laying a tape horizontally across from the left side of the front point area of the rear share (sometimes called the "lay") over to the leftside (inside) of the front bottom landside.
riverbend
02-15-2005 16:24:48
If the bends in the standards that go down to the share go out, it is set up for 16". If they come in, it is set up for 14".
JMS/MN
02-15-2005 16:04:34
Measure the distance of the beams that run front to back on the plow- left side of one beam to left side of the next beam.
Leroy
02-17-2005 16:27:29
 Re: JD-44 H Plow in reply to JMS/MN, 02-15-2005 16:04:34
That does NOT work on a J D 44 plow as they are an adjustable plow, small frame for 12" or 14" cut with a frame measurement like you say of 13" and a large frame for 14" or 16" cut with a frame measurement of 15". you change the front and rear shanks on the frame to change width along with reversing the furrow (Not the tail) wheel
