Building a bucket for my JD 45 loader
Tom in Jersey S
02-14-2005 14:51:52
Hello,
I am preparing to build a new bucket for the model 45 loader on my 60. I also am planning to make this bucket fully hydraulic with rear mounting (as newer buckets are). Obviously this is going to involve significant fabrication. I"ve been, and am still, searching the archives for information on this.
My question is - can anyone recommend what they think would be the proper overall width for the bucket itself without causing stability (or other) issues. I had planned on a 60 inch bucket. The stock bucket is 42 inches. After a discussion I had today with another "tractor guy" I am giving thought to making the bucket only 54 inches wide.
Any opinions or experiences are appreciated.
THANKS
Tom
I Bleed Green
02-14-2005 17:38:14
 Re: Building a bucket for my JD 45 loader in reply to Tom in Jersey Shore, 02-14-2005 14:51:52
I have a 45 loader on my 520. I also have the John Deere 80 inch unitiyl (snow bucket) that i use for snow. I have calcium chloride in the back tires and 2 wheel weights on each side. I can fill this 80 inch bucket with as much snow as it can hold, and i never feel like the tractor will tip. I have the brochure for the 45 and 45-W loaders. If you would like to see it e-mail me, i will scan it and e-mail it. It has pictures of the buckets and of the hydraulic dump.
Tom in Jersey Shore
02-14-2005 18:33:56
 Re: Building a bucket for my JD 45 loader in reply to I Bleed Green, 02-14-2005 17:38:14
How do you have that 80" bucket fastened? Does it fit in the standard holes for the model 45?
I appreciate your offer on the brochures, but I have a manual for both the 45 and the hydraulic 45 loader.
What if you load rocks or dirt in that big bucket - any instability then? This fella I'm talking to says if I build to big of a bucket I risk overloading the frame of the loader, or possibly the frame of the tractor, and could actually "break" the tractor in half.
Any thoughts on that one?
I Bleed Green
02-15-2005 15:48:30
 Re: Building a bucket for my JD 45 loader in reply to Tom in Jersey Shore, 02-14-2005 18:33:56
It goes on the regular bucket. It has clips that go over the tines, and 4 bolts that bolt to the sides of the regular bucket.
paul
02-15-2005 05:10:15
Certainly. It all depends on what you plan to load, how you plan to use it.
Tractors & loader frames bust all the time because people overload them.
You can make a large, lighter-weight snow bucket for lighter use in bulky light-weight stuff; or a smaller, strong & tough dirt & gravel bucket.
A wide bucket in tough materials will always want to twist & break things, as one catches things on an outer edge. And, overloading a bucket with heavy stuff with stress the frame, hitting bumps will stress it more. Overloaded, something will give.
--->Paul
SJ
02-15-2005 08:58:16
 Re: Building a bucket for my JD 45 loader in reply to paul, 02-15-2005 05:10:15
I think the bucket on my Oliver 1550 with a Super K loader is too small,so how do I know how much bigger I can go, I have a loader manual some where ,will that tell me? Ill mostly be moving manure and some stone(driveway and kennel maintenance).
Thanks Stan
paul
02-15-2005 09:19:17
 Re: Building a bucket for my JD 45 loader in reply to SJ, 02-15-2005 08:58:16
Manure is heavy. Likely the bucket is not too small for that. :) :)
I'd look over the manual, or visit a dealer, & try to figure out the bucket options that were available. Likely there is a small manure fork, small material bucket, and larger snow bucket for options. That would be for solid manure, heavy dirt & so on, and light fluffy stuff. Likely those are probably the right sizes for an older loader for the various tasks, or close to it. If you find more options, then you can match to what you need.
Not much of an answer I guess! :)
--->Paul
