difference between middle buster and sub soiler
bj207
02-08-2005 16:45:05
Northern tool sells one that the blade can be changed from a mid buster to sub soiler what is the difference.Can you use both of them to dig potatoes.
BurlGoat
02-08-2005 17:58:24
 Re: difference between middle buster and sub soile in reply to bj207, 02-08-2005 16:45:05
Use the middle buster to dig up potatoes. Use the subsoiler to break the hardpan.Subsoiler is to narrow to dig your taters up.IMHO
Harold H
02-08-2005 17:07:10
I don't know how to dig potatoes, but, a sub soiler has a chisel point designed to break up the hard pan. A middle buster is a plow share that throws dirt both ways and is used to set up rows.
Harold H
Joe in IN
02-09-2005 07:25:25
 Purpose of Subsoiler?? in reply to Harold H, 02-08-2005 17:07:10
OK break up the hard pan... why does one need to do that? What is the hard pan?(Other than a layer of dirt 2 feet down.....)
Richard Fazio
02-11-2005 11:29:24
 Re: Purpose of Subsoiler?? in reply to Joe in IN, 02-09-2005 07:25:25
What Ray said. I've got just that. About 8" to a foot down, hard as heck. My backhoe has trouble getting through it. I've been looking for a subsoiler. I think I need a real heavy duty one not a northern tools type. Then the problem is do I have enough horsepower with my M.
Tim(nj)
02-11-2005 14:40:27
 Re: Purpose of Subsoiler?? in reply to Richard Fazio, 02-11-2005 11:29:24
Your M has enough HP for 1 shank, but you"ve got to be ballasted for traction. Check with Wengers periodically. They often get pull-type 1 shank subsoilers, and their price isn"t always too high. Sometimes a bargain can be had on a good one.
RayP(MI)
02-09-2005 18:00:38
In some soils, the ground will develop a hard layer just below the plow depth. This layer can make it difficult for plant roots to penetrate, and prevent soil drainage through it. A sub soiler has a long shank designed to penetrate and break up this layer. A middle buster, as described by others has a shorter shank, and a double plow share (like a V plow on a snow plow truck) and is designed to create hills on either side of a v shaped groove in the soil. I use it for creating a furrow to plant young pine tree seedlings. This gives seedlings a little more moisture in dry time, because it gets the grass sod away from tender roots. Also works for creating trench for laying pipes, electrical cables, etc.
Ryan
02-09-2005 10:33:51
The hard pan usually refers to an impermeable layer of clay.
Ryan
