john deere
rubbin
02-07-2005 14:37:19
I am trying to find out what would make a 3-point lift on a tractor act like it has the hiccups. Ive changed all the filters and cleaned the screen ,filled with proper fluid and can"t seem to stop it any help would be appreciated thankyou.
buickanddeere
02-08-2005 00:20:51
 Re: john deere in reply to rubbin, 02-07-2005 14:37:19
Over sensitive setting on the "load and depth" feed back control?
HaySam
02-07-2005 15:04:53
What is the numbers on your Deere' Most likely not getting oil.
mike brown
02-07-2005 15:33:40
 Re: john deere in reply to HaySam, 02-07-2005 15:04:53
Maybe fluid leaking by the seals on the piston allowing the arms to drop slowly. The position sensor detects the change and brings it back to where it is set for then the cycle repeats itself over and over.
