Super A attachments
Rick
11-05-1999 20:59:55
I currently have a farmall Super A with a woods belly mower attached. If I want to add or switch to a drawbar or plow do I have to completely remove the mower assembly or will the drawbar simply attach to the back. Thanks for your help.
Mike
11-11-1999 16:05:04
 Re: Super A attachments in reply to Rick, 11-05-1999 20:59:55
Rick,
Depending on the type of drawbar, but I will take
a guess since I have a Super A as well. I have a regular straight drawbar, which bolts onto the back of the tractor, it can be reversed or used to pull wagons, etc.., so you could keep the wood belly mower on, until you hooked another implement to tow or drag, just so that your mower
does not get damaged.
