J.D. 14T BALER KNOTTER
FRED 53
02-01-2005 07:48:03
OK I have a 14t baler that worked great first year i had it, last couple years knots have been more like a bow knot have switched twine size thicker twine works better but still there, with thin twine knots pull apart, knots lose not enough tension. have replaced rollers, knives checked all gears and set up knotters tension to mannul. what should i check next? thanks
Randy165
02-02-2005 05:44:07
 Re: J.D. 14T BALER KNOTTER in reply to FRED 53, 02-01-2005 07:48:03
I have a book on JD balers. I can scan some of the pages about knotters if you think that would help.
Roger in Iowa
02-01-2005 17:02:46
Smaller twine (diameter) or larger number of feet per bale, i.e. 9000 vs 7200 may require different billhooks (multi-twine). Typically 9000 sisal will work with regular billhooks. Plastic twine almost always requires multi-twine billhooks. Don't try to modify regular billhooks as the geometry is all messed up, if you do.
Make sure the wiper arm knife is sharp and check its travel per the OM. Also the force to move the wiper arm across the billhook to wipe off the knot.
Good Luck
Roger (retired from the 14T factory)
p.s. Your JD dealer should have a video tape about knotters that you or a group might find interesting.
Dick2
02-01-2005 14:37:30
Are there any old guys around that ran binders. A lot of those old guys know a whole bunch about knotters!!!
As I recall, Dad said that certain edges have to be sharp; that they won't grip the twine if they get worn too smooth.
Again, try to find an old binder guy and ask him.
old
02-01-2005 09:17:54
Can't remember what they are called but its probably the little fingers that grab the twine. It would be nice if you where close to me I have one for sale for parts
mike brown
02-01-2005 14:17:37
 Re: J.D. 14T BALER KNOTTER in reply to old, 02-01-2005 09:17:54
I had a 214T and replaced the bill hooks with the ones that are made to handle plastic twine and I remember it being an easy switch.
