JD square baler
JD 5020 guy
01-31-2005 16:37:55
Anybody ever seen or owned a JD 10 High Density baler. I have a brochure for one and I think it would be neat to own one if I ever find one.
David from Kansas
02-01-2005 08:38:54
 Re: JD square baler in reply to JD 5020 guy, 01-31-2005 16:37:55
JD 5020 guy,
There is one in OK it has been at the show in Fairview the past couple of years and the guy bales straw following the combines. I brought home one of the little bales last year just for a conversation piece. The baler is supposed to be high density but the bales were rather lose and light weight. I don't think the tension was cranked down enough to make a good bale. I would think those wire tied straw bales should be like bricks. I don't remember if I have a picture or not, will take a look. I do remember that that baler really rocked the tractor and ran at a pretty fast speed. Must have an extremely heavy flywheel and plunger. David
JD 5020 guy
02-01-2005 12:12:33
 Re: JD square baler in reply to David from Kansas, 02-01-2005 08:38:54
The plunger speed is 95 strokes per minute. I imagine it did rock the tractor pretty good.
David from Kansas
02-01-2005 18:32:36
 Re: JD square baler in reply to JD 5020 guy, 02-01-2005 12:12:33
If I remember correctly, it was being pulled by a JD 60 standard. I checked some of my old photos but didn't come up with anything. Where are you located?
David
JD 5020 guy
02-01-2005 18:55:14
 Re: JD square baler in reply to David from Kansas, 02-01-2005 18:32:36
Montana.
