tiller
okie farmer
01-28-2005 22:21:38
how wide of a tiller can i use with a ford jubilee, if i go with 48" then i have tire track problem,what would be the max width,
Robert in W. Mi.
01-29-2005 12:53:59
 Re: tiller in reply to okie farmer, 01-28-2005 22:21:38
It depends... What will you be tilling???? Sod?? A garden spot?? How much use will it get???? What brand of tiller????? (some go a lot deeper) Do you have many stones in your ground???
Some will "offset" so you can cover one side of the tractor, and just keep going the same way around.
If you want the toughest longest lasting tiller, get a Howard of the proper size for your hp..
Robert
paul
01-29-2005 14:26:36
 Re: tiller in reply to Robert in W. Mi., 01-29-2005 12:53:59
I think his biggest problem will be speed - a Jub doesn't really go slow enough for good tilling in all conditions. Will work for light tilling of established gardens, but will be a chore to create black dirt.
--->Paul
Robert in W. Mi.
01-29-2005 15:11:34
 Re: tiller in reply to paul, 01-29-2005 14:26:36
Well, you don't have to go slow if you have enough pto hp, and the "right" tiller.
On some you can turn the tine speed up to make up for the faster ground speed, but on a 8N this will probable not work.
Robert
