Carb rebuiding?
mandolinjon
01-28-2005 20:14:02
I have been doing some mainteance on my 9N recently including a new paint job. I am about to reinstall the radiator and test the engine to make sure it fires before I put the hood back on. My question, while it is down, should I open pandora's box and take the carb apart? It is accessible with the hood on of course but it seems like a wothwhile thing to do. Mandolinjon
Jerry/MT
01-29-2005 17:49:58
 Re: Carb rebuiding? in reply to mandolinjon, 01-28-2005 20:14:02
It's as easy to take off and rebuild with the tractor put together as it is if the tractor is taken apart. If it has the Marvel-Schebler carb it's a simple rebuild as long as you make sure to CLEAN IT VERY WELL!
KevinDM
01-29-2005 08:17:48
If the tractor ran before,make it run that way again. Then if you are still not satisfied, attack one component at a time until you are. That way you'll know exactly what you did wrong and when.(one bad instructor at comm. coll. can cost thousands and untold strife to straighten a son out after that. Dad may have been in repair business for decades but suddenly knows nothing.) After everything fixed (no leaks) then paint.
mandolinjon
01-29-2005 07:41:49
Thanks for the advise. I think I will button it up without a rebuild since I can get at it later.
dr.sportster
01-29-2005 05:56:09
Golden rule of maintenance:If it aint broke dont fix it.Seriously though I would evaluate what comes new with the rebuild kit.If it doesnt leak at the bowl gasket or something like that it might not improve anything.
Steve from New Holland
01-29-2005 04:34:22
If the tractor runs well and the float is not leaking, I would not touch it. Steve
old
01-28-2005 20:45:23
Yep you probably shound good ahead and rebuild your carb
