Snow Blowers on a skid-steer
Bill from MA
01-28-2005 13:51:11
We have had alot of snow here in eastern MA and for the first time saw the town crews using
blowers on bobcats instead of a bombardier plow
for the sidewalks.
I have read in the past in this forum that plows
are much faster than tractor mounted blowers.
Anyone have skid steer experience ?
Thanks,
Bill
Johnski
01-28-2005 21:32:44
 Re: Snow Blowers on a skid-steer in reply to Bill from MA, 01-28-2005 13:51:11
I work for a highway dept in S.E. Mass and we have been using a Trackless tractor with a snowblower to do sidewalks for the last 2 years. We just got a small Cat skid-steer with a snowblower but it is too wide for the sidewalks we have. The advantage over plowing is being able to put the snow where you want it. We can run the sidewalks and not push the snow back into every driveway so we do not need another truck or backhoe to follow and clean up after. You have to have the right snow conditions or the snowblowers won't work. You just cannot blow heavy wet snow no matter what. The Cat has been a big help cleaning up in close spots around buildings etc. You can get in close and blow the snow out to where the loader can get to it. It also comes in handy on bridges and guardrails. We have angle plows for both machines but have not used them yet. I don't know about you but I've seen enough snow this week for the rest of this year. ;>)
Bill from MA
01-29-2005 07:51:18
 Re: Snow Blowers on a skid-steer in reply to Johnski, 01-28-2005 21:32:44
You can say that again. Blowers seem nice, but we
had a storm earlier in the year, 6 inches of snow
and then 1/2 inch of rain. It all turned to soup once you touched it. Blower won't work under those conditions and it is very heavy stuff.
Bill
ps: I am in NE MA, just inside 495.
RayP(MI)
01-28-2005 17:59:22
Depends on the job you want to do! A blade will move a lot of snow, if you can roll it off to the side, or don't have to push it too far. Soon's the blade is full it's going to dribble off the edges, and you're going to have to make additional passes to clean up what you left. Clearing an area, like a parking lot can take lots of back and forth! If you have a decent snowblower, and can move the snow once, and it's no longer a problem, you can move lots of snow. By their nature, the blowers need to travel slowly, a problem for some rear mount pto driven units on farm tractors, where the reverse gear moves too fast, or you don't have a choice of reverse gears. A hydrostatic drive is a real help, as you can taylor ground speed to the depth of the snow, slowing down in deeper snow, and speeding up in shallower snow. My experience with blowers is that they work best when they're loaded to just about capacity. I have a 4' blower on a 14hp (upgraded to 18hp) hydrostatic garden tractor and it'll move a lot of snow. Traction is very necessary, and I have chains, wheel weights and a rear mounted weightbox to keep those rear tires gripping. When you get to the point that you're moving snow you've moved before, it becomes packed, and much harder to move - either with a blower or blade. Also have a 7,100lb 4wd diesel truck with blade, and lots of experience with both blowing and pushing snow. One nice thing about the truck - you don't get covered with snow when you come around the corner of a building and get caught by the wind! In answer to your question, a skid steer would probably do well either with a blade or blower, but you might want to put chains on front tires to improve traction!
RayP(MI)
01-28-2005 17:49:09
Rauville
01-28-2005 16:05:34
The one nice thing about a skidsteer snow blower is that you can tackle a 10' high drift by starting at the top and working your way down.
We have a Schulte brand blower for our 763 Bobcat, and it has worked fine (when there is enough snow). Amazing, the output those little orbital motors can produce.
