I need your help again with plow questions
Dale-SWMI
01-28-2005 12:05:55
I need your help again with plow questions. A few pages back I posted some questions on parts availability for Dearborn and Ford plows. Based upon the responses I received I was able to verify that parts for both Dearborn and early Ford plows are available locally. I�ve also checked out the Ford 101 two bottom plows that were recommended.
The two bottom Dearborn plows around there are selling for $75 to $125 less than a two bottom Ford 101. The major differences I can see between the implements is that the Ford plows have a shear pin and are constructed of straight stock and bolted plates. The Dearborn stuff seems to be made with a curve cast into the main plow frame members with no shear pin. It looks like the Ford 101 plows will be inherently stronger.
On all the plows I looked at the coulters and land slides seem to be in good shape and rotate freely. The moldboards and plow points seem to be either new or show little wear. So the plows seem to be in equally good condition.
So, now my question. Why would I want to spend an extra $75 to $125 for a Ford 101? Is the shear pin there for equipment safety, (keeps from ruining the plow parts if I hit a rock or root) or is it there for my safety in that it will break away and keep the tractor from tipping back over on me if I hit the same immovable rock or root? I don�t want to foolishly save $125 and put my self in a significantly more hazardous situation.
I very much need some advice and help on making this decision.
Thanks in advance for any help you can give me.
Dale-SWMI
Dale-SWMI
01-30-2005 12:34:42
 Thanks Indydirtfarmer and JHill in reply to Dale-SWMI, 01-28-2005 12:05:55
Thanks guys for the advice. I'm after a 101 this weekend. Because of your advice I feel better about the purchase.
Dale-SWMI
jhill
01-30-2005 10:03:05
 Re: I need your help again with plow questions in reply to Dale-SWMI, 01-28-2005 12:05:55
The shear pins will save wear and tear on you, the tractor and the plow if you are in stoney ground. Also the 101 plow is newer. The old cast beam plows were made to use behind an N series tractor about 22 hp. The 101 plows were made to use behind 800 series tractors (40hp) so they are stronger. The extra $100 is worth it if you intend to use the plow much.
Bret4207
01-29-2005 06:51:00
I looked back through the available pages and couldn"t find the previous post. I have a Dearborn 2 bottom I need parts for. Can you tell me where you found parts? Thanks- Bret
Dale-SWMI
01-30-2005 12:26:36
 Re: I need your help again with plow questions in reply to Bret4207, 01-29-2005 06:51:00
Brett
While I didn't acutaully purchase any parts I checked three places with a "What if I had this plow could I get parts?" question.
I checked at the local New Holland dealer. I gave him the model off of a a Dearborn plow I was looking at. He has some parts. He didn't have moldboards or points. We looked at several other plows both Dearborns and early Fords with much the same story.
I then went to a small Kubota dealer (HFS Tractor) in Baroda, MI near me and asked the guy behind the counter if he could get me plow parts. He pulled out a book and showed me several listings for Dearborn and Ford plows including (I think) boldboards and points.
Finally I filled up the gas tank and drove up to Stamm Equipment in Wayland Michigan. The guy I talked to said he can get parts for old plows. They can get them slavage off of equipment being parted out, or new stuff made by who knows. Stamm seems to have an extensive bone yard.
Indydirtfarmer
01-28-2005 12:13:12
2 GOOD reasons....First is the saftey trip beam. That"ll save you a sore chest if you ever hit anything buried while plowing. I"ve spent too many days on dads old tractors without a trip beam plow. You get slammed into the steering wheel when you catch a root or rock.
Second is parts availability. The Ford 101 is about the easiest plow on the market to get parts for (shares, shins, landslides, moldboards, coulters, ect) Some of the others, old Dearborns included are getting tough to find replacement parts for.
One more reason too.....Those 101 Ford plows pull easy. There"s a huge difference in plows. Not all of them are "light draft". The Ford 101 was one of the best mounted plows ever on the market.
