Correctly Balance a load on a trailor
Louie
01-25-2005 10:32:46
I have just added "flip up ramps" to my 16ft trailor. They needed to weld about an 24inch extension off of the back to hinge the ramps so my bushog would fit onto the trailor, when the ramps were in the transit position. Now the trailer tends to 'fishtail' when pulled without a load. Any fix?
Also when I load the tractor and bushhog what is the proper way to balance the load. I heard the best way is to hook up the trailor to my truck without a load, then take a yardstick to the back bumper of the truck and draw a mark. Then load the tractor and bushhog slowly to the front of the trailor. When the trailor starts to tip forward and the back bumper goes about 3 inches below the mark with the empty trailor, that this is the best indicator for a properly balanced load. Any ideas??
greywynd
01-28-2005 21:51:32
 Re: Correctly Balance a load on a trailor in reply to Louie, 01-25-2005 10:32:46
Ideal is to have 10-20% of the trailer weight on the tongue of the trailer. (If the trailer weighs 2000 lbs, the tongue weight should be 200-400 lbs). When you've added the ramps, it's shifted the weight to the rear of the trailer. Like Rob says, you have to somehow get weight back on the tongue of the trailer. Add weight somehow, move the axles back, take you ramps off...
Mark
RobN
01-25-2005 12:49:41
 Re: Correctly Balance a load on a trailer in reply to Louie, 01-25-2005 10:32:46
The balance point has shifted to the rear by adding the ramps. You need the tongue/drawpole to push down on the hitch - now it's lifting up the hitch. How you do that is up to you. Move the load forward, add weight to the front somehow. HTH.
