John Deere 14T...things to inspect???
kentuckydiesel
01-24-2005 11:29:41
I am considering trading a baler I have for an old John Deere 14T. I need to know what I need to look for as far as normal wear/breakage points and anything else you guys can think of so I can decide if it"s a fair trade. Thanks, Phillip
Randy-IA
01-24-2005 18:27:03
 Re: John Deere 14T...things to inspect??? in reply to kentuckydiesel, 01-24-2005 11:29:41
Probably the same things you maintain on the baler you have now . On the first 14t I bought I checked to see if it would tie first of all . But being new to balers I missed a broken tooth on the inside knotter , the rotted out resisters in the bale chamber , the homemade needle drive rod that eliminated the shear pin , the cracked bale chamber up in front , the half worn through twine guides in the needles , the place on the inside needle guard where the twine had worn halfway through the tube , and the bad pitman bushings . So check these areas . This baler tied and released knots during all the dry runs I put it through though . All I'm going to do to it is replace the pitman bushings this spring and sharpen the knives and twine cutters . We'll see....Randy
Bernie in MA
01-24-2005 17:58:20
My 14T had to be replaced because of it's being outside. Chaff builds up on the sheetmetal on the underside of the pickup. Once it gets wet it holds the moisture and the strippers and their supports rust and rot. I don't let my 24T get wet and I blow it off and spray oil it at the end of the season.
Make sure the device that sticks up into the bale chamber when the needles are up still has it's spring and is working, or you'll eventually bale up your needles. Just a couple things I learned the hard way. HTH
JMS/MN
01-24-2005 21:52:38
 Re: John Deere 14T...things to inspect??? in reply to Bernie in MA, 01-24-2005 17:58:20
That 'device' is called a plunger stop. Very important that it is lubed and working properly. It shears the drive pin on the flywheel so the plunger does not cut off the expensive needles when they are in the way.
