juj, our pumpkin/squash planting setup
knauffj
01-24-2005 06:58:43
Sorry about being so late on getting back to you. I asked that guy about the set up. We have a JD 7200 Max Emerge II 6 row corn planter. This is what he said: 1. Set population to the lowest drive 2. use #1,3, and 6 rows 3. set vacum at 8-10 pounds (if you have a vacum pump) 4. use large corn plates for medium/large pumpkins 5. use small seed plates for squash, pie pumkins, and gourds He also said that it takes alot of trial and error to get the desired planting range. He perfers to use the six row planter, but I have an old JD 4 row that was made into a 2 row that, in my opinion, does a better job, if you pick the right plates. Hope this helps some. Good luck!
juj
01-26-2005 04:55:19
 Re: juj, our pumpkin/squash planting setup in reply to knauffj, 01-24-2005 06:58:43
thanks
