Re:Pictures up at the Implement section
chip man
01-23-2005 16:22:48
Al, My dad had a few 'A's with some home made attatchments, so yours is not unusual. What you need is a link between your landplow lift and your lever. it needs to be on the left side of the tractor, so perhaps your double levers would work. it also should lift when the lever is moved forward. the assist spring is a long coil spring, like a garage door assist spring, that goes fom the lever forward to a fixed anchor point in the square cultivator mount hole. I hpoe this helps. tm
Al Fitch
01-29-2005 11:28:42
 Re:Pictures up at the Implement section in reply to chip man, 01-23-2005 16:22:48
TM:
What you said makes sense in that I was thinking the guy who owned it showed me in July that the plow assist goes on the left side and that the handles I have seem to be made to fit on the left side. After that, I"m lost.
However, I was able to rig something up with climing slings, carribeaners and another handle that mounts on the right side of the Transmission block of the tractor engine. This lever location is about 3 feet forward of the seat.
It should work through the season then I will have to do a lot of research and try to get with some local farmers or tractor enthusiasts around me.
Al
