sitrex fold up hay tedder
farmertee
01-20-2005 19:21:47
Anyone know anything about these machines. I am trying to purchase one and wanted to know any faults of this unit. It will tedd up to 17' when folded out.
JiminIA
01-21-2005 06:13:29
 Re: sitrex fold up hay tedder in reply to farmertee, 01-20-2005 19:21:47
The strex we bought 4 years ago is a big improvement over the tedders of twenty yrs ago(wider heavier tires,heavier frames, frame to gaurd tine rotation etc.) They can be a little unstable when folded up in transport position, you just have to be sure when you park or unhook it you have the weight leaning foward or a good wind will blow it over..... Jim
Flurette Farm
01-21-2005 05:56:33
I've owned one for several years and am completely satisfied with it. I don't however ted hay if it isn't necessary. If the weather is in my favor and I've cut & conditioned since the drying time will be very short I rake & bale. Usually I only get out the tedder to shake the moisture off after an overnight shower. Good luck.
James in NC
01-21-2005 05:35:56
As far as construction goes I would say they are average for hay tedders. They are made in Italy, most of todays tedders are. I would put them in between the agrisupply tedders and the high end tedders like the Krone. We sell both the Sitrex and the Krone and there is a place for both. Find a dealer and parts should not be a problem.
