Easy New Holland baler question
ChrisL
01-20-2005 19:11:04
OK a friend was using a 67 (maybe a 69 - doesn't matter) New Holland baler in dry hay that was mainly brome.....the problem is the quality of the bales - it seemed like the bales weighed enough, but no matter how much we tightened down the pressure on the bale chamber the strings were still way loose.... the bales would get heavier but the string still seems saggy - both sides about the same.....
ChrisL
01-21-2005 08:05:16
 Add'l Info in reply to ChrisL, 01-20-2005 19:11:04
was using brand new sisal twine
it already has 3 or 4 (we had to take the plunger out) of the side bars in he chamber - seems like 3 on one side and maybe on on the other side
Joel Harman
01-21-2005 09:37:57
 Re: Add'l Info in reply to ChrisL, 01-21-2005 08:05:16
Need same number of wedges on both sides.
Joel Harman
01-21-2005 06:25:05
 Re: Easy New Holland baler question in reply to ChrisL, 01-20-2005 19:11:04
how old is twine? sissal or plastic?
RickB
01-20-2005 19:40:00
Check to see if the bale case wedges are intact. There could be mounting holes in the chamber for up to three pairs; I would install at least two, if you already have two pair and can install three do so. Check hay dog and their springs.
