PTO buzz saw
BigR
01-20-2005 19:04:59
I have an old buzz saw that I would like to use but the only tractor I have with a belt pulley is a Allis C. I would like to put it on a tractor with a 3-point. Looking at it it seems a buzz saw could run off of a PTO. Looks like it would be easy to add a gearbox and a PTO shaft. Any knowledge or thoughts regarding this in YT tractorland? Thanks for any help!!!!! !!
Rod (NH)
01-21-2005 20:22:10
 Re: PTO buzz saw in reply to BigR, 01-20-2005 19:04:59
Hi,
You can use a right angle gearbox and v-belt speed-up drive to the saw arbor. I did that a few years ago with a neighbors buzz saw in order to run off his PTO. I think his tractor was an AC D15. Worked slick. As I remember it was a 1:1 gearbox I picked up - at Surplus Center I think. I forget what the pulley sizes were but I used a double "B size" belt configuration. A typical wood crosscut saw ought to run somewhere between 7000-10,000 surface feet per minute for the best cutting action. I use a flat belt-driven buzz saw on my AC-B. I like to keep the throttle position around 1/2 full. I don't care to run at full throttle. It's not necessary at all. I have enough power at 1/2 throttle and you should have also. I use the standard 8" dia belt pulley and a 6" dia arbor pulley. I recommend if you proceed with the PTO drive mod that you plan on something less than the 540 PTO speed since that would require full throttle operation to get the saw up to where it should be. It will work at most any reasonable speed but since you are changing things around anyway, why not shoot for the most efficient speed at tractor part throttle?
third party image Rod
Dave Sherburne, NY
01-21-2005 07:53:35
Mine was made from a New Idea Hay Conditioner
worked quite well.
JiminIA
01-21-2005 06:22:17
My dad has a dearborn buzzsaw, it has a 90" gearbox that bolts to the tractor. I dont' know if anyone still makes them or not, but maybe you could find an old one and make it work somehow...Jim
paul
01-21-2005 06:14:43
You need to speed it way up, & the slip the belt provides is a good thing, so speed it up with belts, not chain.
--->Paul
RJ-AZ
01-20-2005 19:34:40
I saw a guy strip a forage chopper down to just the toungue and running gear, drive line and 90 degree gear box and then mounted a saw onto the gear box. wirh a direct drive chain and sprocket type coupler. On a 540 rpm PTO it ran too slow. So he had to put in a set of double pulleys and V-belts and stepped it up some. He runs it with an MD and works real good.
