Need NH 256,258,or 260 rake parts
Phillip Womble
01-20-2005 10:29:56
Need a tine bar for New Holland 256, 258, or 260 side delivery hay rake. Local dealer wants about $350 for a new one. All I need actually is the end off a tine bar to replace one that is worn out. THAMKS!!
kyhayman
01-21-2005 09:03:20
 Re: Need NH 256,258,or 260 rake parts in reply to Phillip Womble, 01-20-2005 10:29:56
Try another NH dealer, I got one last summer for $135. Thats just the bare bar, no bearings, or teeth. You may have already checked but is the ring groove damaged or just in need of a bearing in there. Only times I've had to replace bars b/c of the ends was due to groove damage. Bearings arent bad at all, less than $30 will change out the end.
je
01-21-2005 06:01:47
Which bar do you need there are two different bars. I have some bars i would cut the end off of and ship to you.
Phillip Womble
01-22-2005 14:59:24
 Re: Need NH 256,258,or 260 rake parts in reply to je, 01-21-2005 06:01:47
JE - please check your emails. THANKS!! P.Womble
IanC
01-21-2005 13:33:16
there are actually 3 styles. The first used a stud pressed into a bearing and was replaced as an assembly, second design used tapered roller bearings with a seperate stud, latest version uses same stud as second, and regular roller bearings. $350 sounds high for a bare bar, I"d call a couple of other dealers. Also it"s coming up on "Open House" time for most dealers, so you may be able to get a deal if you are willing to wait a while.
