John Deere 410 Baler
MH
01-20-2005 05:11:47
Posted a question about round balers a few weeks back, and I have found one that I am interestd in. It is a John Deere 410. I just have a few questions. What size bale does it make? How old are these machines, and are they reliable? What should I look at to determine shape other than overall apperance? What is a fair price range for this machine in NC? Thanks ahead of time for your help.
Bob Semrau
01-21-2005 10:06:46
 Re: John Deere 410 Baler in reply to MH, 01-20-2005 05:11:47
I own a 510, the bigger brother of your 410. The only thing you need to be careful of is that the hay must be totally dry before baling. If it has any moisture, the hay will wrap around the inlet rollers. I have never had it plug on me, and it starts bales easily, unlike some other balers. When starting the bale, you must watch how it forms and make sure hay goes on evenly. It does not make as tight a bale as some of the newer, more expensive balers. If you pay attention to the machine you will not have any problems using it. I paid $1800 for mine 3 years ago, probably a little too much, but it was in very good shape, and has been a good baler.
Coaltrain
01-20-2005 09:54:46
MH I used a 410 for a few years back in the 80s, they will test your patients. When James stated closed throat baler he made a true statement. The material must go thru two rollers one with belts to carry the material back to the bale and one to press the material down to it, if the material is to dry to wet or to large to go between it plugs and you must dig it out. Rocks sticks, turtles, or bones will plug it. It will not unplug by just by dumping the started bale most of the time. One word of caution while baling and pluging and digging the hay out be sure to turn off pto before getting off the tractor. I thought had one time and as I was digging the hay out of the baler it started, almost pulling me in the bale the slip clutch was slipping (not smoking like it should have been) leaving me to belive I had shut the pto off.
James in NC
01-20-2005 05:29:37
They make a 4X4 bale and are a closed throat baler. Check the condition of the bottom belts and rubber roller. To replace them it costs more than the baler is worth. We sold one last year for around 1,000.
