Best Rear Blade made for Massey 135 Tractor
Willy-N
01-16-2005 22:52:52
I am pretty hard on my Rear blade and have broke it several times at the 3/point attachment points. Never bent the blade it is very strong. In the future I will be getting a new one and was wondering what is a real good stronge one? It needs to be at least 7 ft wide, tilt and rotate around. Thanks, Mark H.
jhill
01-17-2005 13:04:19
 Re: Best Rear Blade made for Massey 135 Tractor in reply to Willy-N, 01-16-2005 22:52:52
Willy-N,
I have a Service Rhino blade I use on my 3000 Ford. It is a heavy blade. Made for 100 hp tractor. It does not use pins that go thru the 3pt arms. It has a lower cross arm that has tabs with holes in them. A pin goes thru one tab then the 3pt arm then the other tab. You could do something similar to your blade.
Willy-N Yes!
01-17-2005 14:44:12
 Re: Found it! in reply to jhill, 01-17-2005 13:04:19
I found one and see what your talking about. That looks like a strong way of hooking them on. Two Tabs one on each side ot the Lower Link Bar and a pin thru them. That would take the bending motion out of the pins. Did notice you have to get above a 100 hp+ Blade to get a blade as strong as mine is built! There Cat I style looks like it would bend easy not much bracing on the blade. I know my blade weights around 450-500 lbs and the Rhino small ones are around 300-350 lbs of steel. Mark H.
jhill
01-18-2005 15:21:34
 Re: Found it! in reply to Willy-N Yes!, 01-17-2005 14:44:12
From the pictures I see of you blade It does appear to be quite well built except for the 3pt hookup. I would rework it along the lines of the Rhino and I think that should do it.
Ypu know when they build equipment for Arctic use they use special steels this is for work at -40 I foyur like I am I have had alot of -10 weather so the cold could have some effect on the brittleness of your steel too.
Willy-N
01-19-2005 07:16:36
 Re: Found it! in reply to jhill, 01-18-2005 15:21:34
I was thinking of that myself. These problems seem to happen when it is real cold out! I busted the big bolt that holds the whole blade on in the tilt tube. It was a 3/4 inch bolt and I up graded it to 7/8" yesterday. Mark H.
Willy-N
01-17-2005 14:31:17
 Re: Best Rear Blade made for Massey 135 Tractor in reply to jhill, 01-17-2005 13:04:19
Got a picture of it or a model number so I could look one up? Mark H.
leland
01-17-2005 07:53:58
buy a heavy blade like rinho or bushhog then you will be breaking 3pt lift arms instead of blades. Take allan advise buy a real heavy duty piece of equipment.
Willy-N
01-17-2005 11:26:41
 Re: Best Rear Blade made for Massey 135 Tractor in reply to leland, 01-17-2005 07:53:58
third party image
The Massey 135 Orchard uses a 165 Rear end so the Lower Link arms are real strong. They are over 3/4" thick and the arms supporting them are BIG! Picture does not do the justis but I don't think they would break very easy. The point the upper link hooks into is also over sized also. The top link that broke was Cat II but it broke on the end not on the tractor cause the blade swung around and worked like a lever on it. Mark H.
Willy-N
01-17-2005 11:25:54
third party image
leland
01-18-2005 18:59:09
 Re: Best Rear Blade made for Massey 135 Tractor in reply to Willy-N, 01-17-2005 11:25:54
Willy I have many hours on a 165 and those arms will break tore one up mowing pasture.
Willy-N
01-19-2005 21:39:37
 Re: Best Rear Blade made for Massey 135 Tractor in reply to leland, 01-18-2005 18:59:09
I was just compairing them to the Cat I 8N Lower Link Bars and they are at least twice a large. I know all things will break but for the size of the tractor they are pretty big. Mark H.
Allan in NE
01-17-2005 07:04:30
Hey Mark,
Have you given any serious consideration to a CAT II hitch? That'll put the whoa to that cow pie problem of yours. :>)
Allan
third party image
Skyharborcowboyjoe
01-17-2005 07:44:35
 Re: Best Rear Blade made for Massey 135 Tractor in reply to Allan in NE, 01-17-2005 07:04:30
What are the differences between a #1 and #2 Hitch? Which is more common? Which has more support with varieties of implements for a small acrage property?
Joe
Allan in NE
01-17-2005 07:54:06
 Re: Best Rear Blade made for Massey 135 Tractor in reply to Skyharborcowboyjoe, 01-17-2005 07:44:35
Hi Sky,
CAT II is just a beefier outfit.
I don't ever remember seeing a CAT II pin snap. I think they are 1 1/8" diameter or something like that.
Allan
paul
01-17-2005 11:07:43
 Re: Best Rear Blade made for Massey 135 Tractor in reply to Allan in NE, 01-17-2005 07:54:06
The 3pt pin specs are on the menu to the left, under research & info heading. I believe cat 1 should have the pins 26 inches apart, cat 2 is 32 inches apart.
I broke a cat 2 pin off a JD plow. Have I mentioned we have rocks? :)
I too would be concerned with the cat 1 stuff, if you get a heavy enough blade & yoke that it never breaks, the cat 1 hitch on the tractor is likely the next to go! I have a rather flimsy cat 1 blade that we've used on the Ford 960 for years, I bowed the blade slightly on cow pies.
This fall I got an IHC cat 2 blade for my bigger tractors, we will see, I have not taken the opertunity to use it yet. We have only had an inch of snow & ice here with the sub-zero temps. Surprised the water keeps working, there are 4" wide cracks in our drier than average & un-insulated soil that go a couple feet deep....
The switching point on tractors seems to be about 65-75 hp - those above are cat 2 to take more hp; those below are cat 1 which is the Ford N standard. Both are equally common, just depends on the size of your toys. :) It is possible to cross-use them, not always at the easiest or the wisest.
--->Paul
Willy-N
01-17-2005 11:38:53
 Re: Best Rear Blade made for Massey 135 Tractor in reply to paul, 01-17-2005 11:07:43
third party image
It seems the Cow Pies are the only thing that has realy gave it trouble or frozen in rocks. The blade has never bent yet and is very strong. I probley should use my new welder to make a new 3/point mount for it. Not sure these new pins will snap now they have 1 3/4" nuts on them and are case harden ones. Same as a Cat II Mounting hole but the pin is a little smaller that goes into the link arms. They also have a sholder which the other pin was just a bar that went across the blades support. Mark H.
paul
01-17-2005 12:22:26
 Re: Best Rear Blade made for Massey 135 Tractor in reply to Willy-N, 01-17-2005 11:38:53
Yes, that looks about like a medium cat 2 type of blade. So the cat 1 pins are most likely the weak point. I would maybe want to leave it at that with a cat 1 tractor, not get it too strong. :)
My cat 1 is a little 6', no backbone to it. It held up amazingly well for the abuse it got, clearing snow & some of the cattle yard for decades. I have on crack in my feeding platform that the frost heaves, have to go _real_ slow in that spot every time....
The big one I got I plan to use with dirt a bit more, need more oomph for that.
--->Paul
