Drum Mowers-CCM-Others
Kurt Smit
01-16-2005 17:38:56
How do these drum mowers work? Are they a flail type of mower like a NI cutditioner or MC rotary scythe? Or something else? Do they come in a pull type version with around a 9 foot cut? If they do does that meke the price jump up to a conventional mower range? Any info would be great.
Thanks,
Kurt
Hay Dr
01-16-2005 18:10:26
 Re: Drum Mowers-CCM-Others in reply to Kurt Smit, 01-16-2005 17:38:56
third party image
CCM Drum Mowers work just like a disc mower but instead of using 18" disc to hold the blades they use large drums. The CCM drum mowers cut in the same way as a disc mower. The niche for these CCM drum mowers is usually for farmers that harvest less than 100 acres of hay a year. CCM largest mower has a 75" cut and can be used on a 35 HP tractor. Drum mowers work best in even number drums. To have a 4 drum 7'-9' 3 point drum mower would require a 85 HP tractor. Usually farmers choose disc mowers for cuts 7' and above. No exterior hydraulics are needed to operate the CCM drum mowers. This is a simple and durable technology that is very cost effective.
Kurt Smit
01-17-2005 16:12:22
 Re: Drum Mowers-CCM-Others in reply to Hay Dr, 01-16-2005 18:10:26
Thanks! The idea sounds good but I guess I need something a little bigger that also crimps or flails.
Kurt
Hay DR
01-17-2005 17:01:22
 Re: Drum Mowers-CCM-Others in reply to Kurt Smit, 01-17-2005 16:12:22
third party image
The T-185 drum mower will mow 5 acres an hour. And with a 18' tedder you will put hay up faster than any mower conditioner used by itself. Mower conditioners are only beneficial in legume crops.
