Allis toolbar. Will it hold up planter units?
R Wyler
01-15-2005 18:27:08
I bought an old Allis cultivator yesterday it is from a WC and will be very easy to rig up on 3 point. It is actually a field cultivator but will work well for my garden. I was also wanting to use it for 2 Allis planter units. This bar is the solid stock not the thick walled tubeing that the bar on my planter uses. Will this tool bar twist or will it hold these units? I sure do not want to ruin the tool bar. Anyone ever done this? Thanks
riverbend
01-18-2005 06:18:16
 Re: Allis toolbar. Will it hold up planter units? in reply to R Wyler, 01-15-2005 18:27:08
I hung (4) JD 70 planters on a 2 1/2" square tube, 1/4" wall, and have not had any problems with twisting or sagging. The manual says that the planter units weigh 105 pounds, but that seems too heavy, I'd say they are closer to 70 lbs. The planters are all close together at 10".
R Wyler
01-18-2005 06:21:49
 Re: Allis toolbar. Will it hold up planter units? in reply to riverbend, 01-18-2005 06:18:16
Well that is encouraging. I think I will go ahead and put them on mine. 1/4 inch is not very thick. My units are problably about 70 to 80 also. Thanks. R Wyler
riverbend
01-19-2005 07:11:13
 Re: Allis toolbar. Will it hold up planter units? in reply to R Wyler, 01-18-2005 06:21:49
I ran out and checked, it is 1/4" wall. The inside planter units are between the top link mount and the pins that go through the 3 point arms. The outside units are just on the other side of the pins.
Greg
R Wyler
01-19-2005 16:18:49
 Re: Allis toolbar. Will it hold up planter units? in reply to riverbend, 01-19-2005 07:11:13
Thanks for the Help Greg and going and takeing the time to look at yours and tell me. Mine will be like that. The units will be close to the center of the bar. about 30 inch spaceing. Just 2 rows.
riverbend
01-19-2005 19:25:10
 Re: Allis toolbar. Will it hold up planter units? in reply to R Wyler, 01-19-2005 16:18:49
You're welcome
R Wyler
01-19-2005 19:32:03
 Re: Allis toolbar. Will it hold up planter units? in reply to riverbend, 01-19-2005 19:25:10
thurlow
01-17-2005 16:21:31
Had one from the factory with 4-plow middle busters on it..... .about 3 and a half or 4 inch solid as I recall; looked overloaded, but never twisted or bent it..... .can't imagine a couple of planter units would hurt yours..... ..depending on size of it.
R Wyler
01-17-2005 16:27:32
 Re: Allis toolbar. Will it hold up planter units? in reply to thurlow, 01-17-2005 16:21:31
Was it an Allis? This one is about 2 1/2 inch in diameter. I may try it and see what gives. :>)
paul
01-17-2005 11:18:01
How big is the shaft???? You didn't say. How wide is it? If it would cover 4 rows, a field cultivator likely puts more stress on it than a 2 row planter, which I believe you are building. Perhaps raised up & boxes full you could twist it tho on a bump - your planter units were kinda large & rer-weighter weren't they?
--->Paul
R Wyler
01-17-2005 16:26:09
 Re: Allis toolbar. Will it hold up planter units? in reply to paul, 01-17-2005 11:18:01
Well it is really a field cultivator and is wide enough to cultivate 2 rows the shanks are very small and dont weigh very much. The bar is just a little smaller than what my planter has I think. It does look pretty stout though.
thurlow
01-17-2005 21:12:13
 Re: Allis toolbar. Will it hold up planter units? in reply to R Wyler, 01-17-2005 16:26:09
Mine was an A-C; had those huge A-C trip bottom busters on it; sounds like you're talking about a row-crop cultivator rather than a field cultivator????? ????? In my part of the country, field cultivators only came into general use in the 60s/70s..... ...
R Wyler
01-18-2005 06:18:23
 Re: Allis toolbar. Will it hold up planter units? in reply to thurlow, 01-17-2005 21:12:13
Ok Thurlow. Yes this is actually a field cultivator it is an early one. I think it is for a C Allis tractor fullty mounted. But I looked at pics pf ones like mine in my Allis book and they are a field cultivator. It is made differently than the row crop ones.
