Mixer/Mill Recommendations?
Phil Crome
01-12-2005 16:48:22
I'm looking for ideas on a good, small mixer mill setup that can be used comfortably with a Ford 860 to make assorted cattle and sheep feed mixes. Nothing fancy, but sized right to produce batch sizes not to exceed 1000#. A cement mixer isn't near big enough. Used preferably.
Regards,
Phil Crome
Mike Aylward
01-15-2005 16:25:07
 Re: Mixer/Mill Recommendations? in reply to Phil Crome, 01-12-2005 16:48:22
Phil, your tractor should be able to handle most any 2 to 3 ton mixer. If you are only going to do half a ton at a time you should be fine. Your tractor will handle a good-sized mill just fine as long as you control the feeding rate of what you are grinding. Unless you have a real horse on them you seldom feed them fast enough to use everything the mill has. Mike
RJ-AZ
01-13-2005 20:45:28
I used to run a small Farmhand mill with a Ford 3000 diesel.Can't remember the model but it was the smallest mill they made.
