Mow grass with Gator
NutMan
01-12-2005 01:42:54
Hi folks,
I'm just wondering if anyone has tried using a john deere gator to mow grass. I've noticed the self driven mowers that pull behind an ATV. Which would likely work fine with a Gator.
But I need to mow real close around rows and rows of small seedlings I am and will be planting.
What I'm curious about is if one of these mowers could be mounted to the front of a gator and pushed.
Anyone tried this?
Thanks,
NutMan
CJ-maybe
01-14-2005 14:39:42
 Re: Mow grass with Gator in reply to NutMan, 01-12-2005 01:42:54
Have a couple Swisher tow models(TSC),pull with a front mtg.Looking at them(& trying to dream up new ideas)got a couple.I'm thinking turning's the problem.Either a long hitch over the mower so it's actually being pulled,not pushed,that way it can turn normal,not slide.Or make it like a regular front mtg,put caster wheels front and back and push it,then its solid & you can steer it & back up.Maybe look at a 3pt finish mower to get an idea,the tire issue will make sense.Having a frt mtg,it's a nice way to go,I think.Work up some brackets and go for it.
CJ-maybe
01-14-2005 14:47:27
 Re: Mow grass with Gator in reply to CJ-maybe, 01-14-2005 14:39:42
Just went to the Deere site(had'nt in awhile),found brooms & plows for gators.Seems like a good start/build from.
Andy(PA)
01-13-2005 08:28:25
I use a 6X4 gator with a pull behind MOTT mower (hammer knife mower, 8 horse engine) that works well on tree farm.
Loren-MN
01-13-2005 05:45:54
A local fertilizer company uses a Gator and self-powered pull behind mower. I believe the mower is from TSC and is a 60" cut. It can be pulled directly behind or hitch can be offset to one side for closer mowing.
BobMo
01-12-2005 16:49:47
I guess your choice was mower or gator and now your selection has came back to haunt you....
Oh well I'd probably done the same thing....
NutMan
01-12-2005 18:08:49
 Re: Mow grass with Gator in reply to BobMo, 01-12-2005 16:49:47
BobMo,
Oh, I love my gator. Handiest thing yet, well, except for a skid steer. Can't begin to estimate the steps it has saved me. Just don't want to invest in another machine if I can use it to mow...and still have the bed to pickup / carry things.
Best,
NutMan
BobMo
01-12-2005 16:42:00
johndeereman
01-12-2005 11:26:19
i might be mistaken but i think they make a mower for the front of a gator try checking with youre dealer
NutMan
01-12-2005 18:10:11
 Re: Mow grass with Gator in reply to johndeereman, 01-12-2005 11:26:19
Really? I'll check. Funny, nothing on the web site.
Thanks,
NutMan
James in NC
01-12-2005 07:26:36
Design and bracket and go for it. I think it would work. I would try it with a regular push mower first to prove out the idea before spending a lot of money.
NutMan
01-12-2005 18:12:12
 Re: Mow grass with Gator in reply to James in NC, 01-12-2005 07:26:36
James,
Not sure what you mean by "push mower". If it doesn't work I can always pull it the way it's supposed to work. Sure would be nice to hace it up front though.
Thanks,
NutMan
James in NC
01-13-2005 13:32:02
 Re: Mow grass with Gator in reply to NutMan, 01-12-2005 18:12:12
Push mower like the one you buy at lowes and home depot for your yard. gang a couple together on a bracket and attach to the front of the gator and try it out, won't look pretty but it might work.
