Greeting Chuck, I used to in Mich. Little town called Portland...down by Lansing. "You say that you have grass strips but have yet to till? Did you spray? Did you add a pre-emergent herbicide? If you did and you till, you'll churn up new weed seeds" We did not spray. I am real leary about spraying, even with roundup based upon my experiences last year. Let me expand on that because it is a dilema. We planted into 10 acres of former corn ground after being told by chem company that there would be no carryover (we just bought the land, so we did not know what went on it, we found out and asked). There most definitely was a carryover. The plants greened up, dried up and droped their leaves. They then greened up again and dropped again. And a third time. Don't know how they had any energy left for the third try. It wasn't moisture, we had good rain, and I used drip tapes in August to keep them moist. During the year we did a combination of mowing, hoeing (hand) and cultivating (with a 3ft wide disk)....to control weeds. Note that some areas of the field did not even produce weeds, so I have taken this as confirmation of carryover. As I observed this taking place, I noticed that the plants that did the best seemed to be the ones that had MORE weed cover. This led me to wonder if, perhaps, the hazels did better with shade. The greenhouse disagrees, but I wonder, and think that this year I will mow along the rows, but let the grass grow up around the tublings. Your thoughts? We are located in SW Wisc, not far from Dubuque IA. I would imagine our soil is quit a bit like yours. Extension tells me that the soil is "Dubuque Silt Loam". About a 10-15 percent slope. I wonder if since these grass strips have not been croped for a number of years (some of it never), why there should be a need for breaking a hardpan. I even wonder if that is an issue anyhow. The first year or so (the critical time), they are not putting roots down 2-3 ft anyhow. Or so I would assume. Once they have survived a year, I think they will punch through it anyhow. What would be your thoughts on these ideas from a novice? Note that we will only be planting 6000 plants on 10 acres. 3 ft between plants & 20 ft betweem rows. Our Holland has a 2 ft colter. We did plant into some pretty hard soil last year (had clay), and it seemed to cut through OK. The problem was with closing the trench. On option I was considering was sharpening (and keeping sharp) the planters blade, lowering the colter a bit more (has to be cut and welded) and applying some tractor wts to the back to help close the trench. Even with that, I doubt I can drill right into sod. Would be nice if I could (?). The Holland I bought runs on a wheeled cairrage, not 3 pt. I was hoping this would work better on hour hilly ground. If you have some experience with this, let me know what you think. Thanks so much, NutMan
