Hyd. Cylinders on Implements
rwood
01-03-2005 12:45:35
I have a Ford 5000, single lever hyd. system. When connecting "lift" and "drop" hoses to implement hyd. cylinders, which port on cylinder is considered the "lift" port? Any help will be appreciated. Thanks. (Just got the unit.)
rwood
01-04-2005 07:45:21
 Re: Hyd. Cylinders on Implements in reply to rwood, 01-03-2005 12:45:35
Thanks for the feedback. Bob Mo's remark about the info being in the manual got me thinking: I've got to get over the mindset that exists around here that referring to a manual is a sign of weakness.
JMS/MN
01-04-2005 07:35:47
If your single lever operates a remote with two openings for hoses- either port will have oil under pressure, while the other provides a path for backflow from the other side of the cylinder. Doesn't matter how you hook up the hoses.
BobMo
01-03-2005 18:07:54
Thurlow, is correct but, of course you know all this because its's fully explained in your operators manual..... ..... .....
thurlow
01-03-2005 13:05:22
Well, the cylinder doesn't care; most implements are designed to "push" i.e. extend the ram to lift the implement. Not all do; some pull. If the hoses attach 'one to each end' of the cylinder, then the one opposite the ram does the 'pushing'. If both hoses attach to the same end, you may just have to hook 'em up and try it to see what happens. Simple matter to swap hoses in the hydraulic connections at the tractor..... ..
