7 ft pull-type rotary mower
Shaun in Ky
12-28-2004 12:37:21
Recently acquired a 7 foot pull-type bushhog that is belt driven. I am unsure of the brand, all I know is it appears to be 20-30 yrs old, and it is now Yellow in color. The unit didn't have any belts on it when I acquired it. It consists of one main pulley that comes directly off the PTO drive, and 2 smaller pulleys that run the blades, and a set of idler pulleys. What is tripping me up is all the pulleys have 3 grooves. Is this a serpentine type machine, and how can I find the correct configuration for the belts. Any help would be greatly appreciated.. P.S. This unit may be a LILLISTON.
Indydirtfarmer
12-28-2004 13:05:48
 Re: 7 ft pull-type rotary mower in reply to Shaun in Ky, 12-28-2004 12:37:21
It's got 3 sets of "grooves for 3 belts... They need to be belts intended to run as sets. Gates calls there's "Equi-Match" You'll need to figure out the routing, then take a string or small piece of rope. Feed it as though it were a belt. Tie it off to get the proper size. Take that to a GOOD auto parts store, or a farm supply/impliment dealership. They can then measure it, and get you the belts you need.
I can't help but notice you live in Kentucky... Where abouts? I live in Louisville, and could direct you to a good supplier for belts/hoses/rubber products.
Good luck! John
Shaun from Ky
12-28-2004 14:32:02
 Re: 7 ft pull-type rotary mower in reply to Indydirtfarmer, 12-28-2004 13:05:48
I work as a firefighter/paramedic/farmer in Owensboro.
Hay Dr
12-30-2004 20:21:54
 Re: 7 ft pull-type rotary mower in reply to Shaun from Ky, 12-28-2004 14:32:02
Have you asked Paul O'Brian in Owensboro? He would be the best in your area on shortline parts and identification.
