NH 489 Haybine
rwood
12-23-2004 17:58:06
I just bought a NH 489 and noticed that one of the rolls is beginning to show signs of separation from the metal. I'm thinking of using a polyurethane caulk designed for rubber, vinyl, etc. to try to reattach it after cleaning it up with a solvent and air. Anybody ever try this with any luck?
s
12-27-2004 04:18:55
 Re: NH 489 Haybine in reply to rwood, 12-23-2004 17:58:06
I'd like to say yes, but I'm afraid the answer is no. Steve
rettchr
12-24-2004 09:27:06
On my 479 I used JBweld to reattach a section of the rubber on the upper roll. This worked for a while but was knocked loose. I reattached it with this same adhesive and added a 1/4 inch bolt drilled/tapped into the steel to provide a little more mechanical support. However, I am afraid that both your repair efforts and mine will be temporary at best.
