3 point powerwasher
patrick
12-22-2004 19:37:00
hey guy would like some input on this projct and if you think it would be usefull, all us tractor guys like to keep our tractors and imp nice and as clean as poss. i have gone thu about 2 or 3 powerwashers here at the farm and had it with the junk out there. so this is what i plan to do. have 4 tractors here that have a p.t.o and great h.p to 25 plus h.p!! and i am gong to find a supper high p.s.i pump and make a bracket for 3 point and use p.t.o from tractor to run pump!! i will neaver have to clean carb on power washer. add oil or gas. deal with made in china again!! what do you think?? and input would be great. 25 hp powerwasher. i am going to call sears and ask them if they got one!!
buickanddeere
12-23-2004 17:22:57
 Re: 3 point powerwasher in reply to patrick, 12-22-2004 19:37:00
You are going to have to purchase a premium wand with two very good handles. A 13HP 4500psi 4.0 GPM pump is tough to hold after a while. Danger of hurting yourself or a bystander in fact.
There are only two manucaturers of high pressure pumps worth bringing home and neither are built in North America. The Italians have the market cornered.
If the pump isn't a brass bodied, three piston ceramic or premium three plunger ceranic unit made by Cat. Or the Comet LW,LWS,LWD or the premium ZWD Forget about the project.
These manufactures pumps can be had in low rpm models for pto drive.
Chemical addition after the pumps increases service life. As does pre filters and thermal unloader valves. You don't want to twist a pump drive off or overheat a pump.
These pumps allow a connection direct to your home or shop hot water service.
Hot water through a water softenor and a little soap in a 4500 psi machine works nearly a miracle. All in all it will be cheaper just to purchase an unheated Karcher 13HP gasser 4500psi unit with a hot water capable pump.
