EZEE FLOW HOPPER SPREADER
RMM
12-17-2004 20:47:26
I am looking for information on an AVCO EZEE FLOW spreader (three point mount). I need info on recommended settings etc. I believe the model is a 300? Thanks.
paul
12-18-2004 07:53:53
 Re: EZEE FLOW HOPPER SPREADER in reply to RMM, 12-17-2004 20:47:26
Is this the typical 3pt cone-shaped fertilizer & seed spinner? Many made in Italy & nearby? I also see older drop-spreader with the same name, but those generally are not 3pt....
If the cone spreader, I got an odd-named one without a manual. It appears most come from the same factory, & Worksaver had an entire manual, parts list, & more on their web site for one style - downloadable & printable PDF files. This matches my spinner to a T. I believe I have seen one other type of spinner, slightly different gate openning for seed drop, but even so the Worksaver info would be helpful. I forget their web address, but should be the obvious or search Google, that's how I got it.
If you have some other type of spreader (Avco made manure spreaders too, but not 3pt! :) describe fruther.
--->Paul
wayne holt
06-28-2007 13:11:18
 Re: EZEE FLOW HOPPER SPREADER in reply to paul, 12-18-2004 07:53:53
i have and EZEE Flow spreader it is not a hopper It is a pull behind about 10 feet long .It runs off the wheels 2 sections each off opposite wheels .The bottom closing and distributing section is rusted out.Wonder where i could get parts
paula day
10-10-2007 10:50:21
 Re: EZEE FLOW HOPPER SPREADER in reply to wayne holt, 06-28-2007 13:11:18
Wayne, I have what sounds like the same machine. Wonder if you have the spread rate info that was posted on the inside cover? Mine is worn out and unreadable.
RMM
12-19-2004 16:10:03
Hi Paul, thanks for the help! I will check the Worksaver website. My spreader is the cone type broadcaster as you said. This one that I have has two doors on it with a pin limiter with a bunch of different hole settings to control the flow.
