Hey Bernie in Ma!!!!!
Stumpy
12-15-2004 15:45:09
Hi Bernie, I just read your post about your 24T baler. I live in Southern NH and would really like to see your set up. I am in the market for a 24T to go behind my 2N or my JDB. I am interested in the physical size and how the aux engine is mounted. Would it be a difficult job to add an engine onto a baler without one? Late model briggs maybe?
Thanks for your help
Stumpy
Bernie in MA
12-16-2004 06:50:44
 Re: Hey Bernie in Ma!!!!! in reply to Stumpy, 12-15-2004 15:45:09
Hi. Got this all typed last night and couldn't put it on. Where in NH are you. I'm near the line about 30 miles south of Keene. You're welcome to come look at my setup.
I used a 2-cyl WI engine off another baler, so they are both the same as the original one.I bolted a plate on the flywheel side of the plunger chamber so it stuck up about 4" above the top of the chamber enough to clear the plunger arm, just ahead of the forks. I then welded another plate across the top with a support under the other end and mounted the second engine on it. I used a 2-sheave pulley on each engine with a double vee single backed belt. Both belts go on the flywheel; the one from the original engine on the inside edge and the other one on the outside edge.I was advised to get the crown turned off the flywheel to make it flat which I did, but it might have worked without. That cost $80 and the 2 belts/sheaves were over $100 each. I already had the engine off my parts baler.I had trouble at first with keeping the top (outside) belt on, even tho I was careful to weld the shaft for it's tightener square and level. The problem turned out to be John Deere didn't make their pulley bracket square which I had also taken off the parts baler. Belt tension was a problem at first. Too loose and the belt would come off when it started to slip; too tight and the pulley would heat up. I start the bottom engine, get the baler going and then start the top one by tightening it's belt. This year it worked so good I got heavy bales because of it's not stalling. I didn't realize the hay wasn't dry enough. I won't do that again after having to replace 100 musty bales.
Stumpy
12-16-2004 14:24:18
 Re: Hey Bernie in Ma!!!!! in reply to Bernie in MA, 12-16-2004 06:50:44
I live in Milford,right off rt13 near Chappell Tractor. I might even be going to Uxbridge this weekend to look at a baler, not sure. Where are you?
Stumpy
Stumpy
12-16-2004 14:23:14
Stumpy
Bernie in MA
12-16-2004 16:13:58
 Re: Hey Bernie in Ma!!!!! in reply to Stumpy, 12-16-2004 14:23:14
You'll need to get on Rte 2 headed west. Take exit 18 thru Athol. I'm on 2A between Athol and Orange. Coming from Athol (east, headed west) go past Hannaford Plaza at the Orange town line and take the next right onto East Road. If you go by Hamshaw Lumber you've gone too far. Go 1.3 miles on E RD, I'm on the left.Barn is about 6' off the road, new aluminum roof. Baler is inside. I'll prolly be out sawing wood in the field about .3 before you get to the barn, same side, up behind some woods, except Sunday AM and Sat PM. You can take a look even if I'm not there.
Stumpy
12-17-2004 03:19:39
 Re: Hey Bernie in Ma!!!!! in reply to Bernie in MA, 12-16-2004 16:13:58
Hope to see you this weekend!!!!
Stumpy
I'll be the guy in the green and silver Chevy P/U with my head wagging side to side :)
Stumpy
12-17-2004 03:18:37
Stumpy
