Vermeer disc mower ?
legn4
12-12-2004 07:18:30
Looking at a Vermeer7020. Any body know anything good/bad about one? Thanks / Eddie
James in NC
12-13-2004 05:15:50
 Re: Vermeer disc mower ? in reply to legn4, 12-12-2004 07:18:30
The down side to the 20 series Vermeer's is they are really heavy. With the metal top. They don't take a lot of HP to run but take a lot to handle.
Hay Dr
12-12-2004 12:04:57
third party image
The Vermeer 7020 mower is the same as a Lely Optimo with the exception of Vermeer uses a heavier blade and heavier curtain.
A shaft driven mower like these mowers need 20% less horsepower. You will have less downtime because repairs are cheaper and quicker on a shaft drive mower.
Roy in UK
12-12-2004 23:17:20
 Re: Vermeer disc mower ? in reply to Hay Dr, 12-12-2004 12:04:57
"Need 20% less horsepower". I used to run an 8' Lely mounted disc mower / conditioner ( nylon flails) behind an MF 168 (66 engine hp ) and it handled it like a dream even in thick tangled crops. The Lely is a very good mower and it gave us little or no trouble.
Ken Macfarlane
12-14-2004 05:37:37
 Re: Vermeer disc mower ? in reply to Roy in UK, 12-12-2004 23:17:20
Anyone know some shaft drive models to list out? I am looking for a trailed low hp disc mower conditioner to replace a NH 489. I have no clue which models on the used market are shaft drive or not.
Ken
James in NC
12-14-2004 07:48:07
 Re: Vermeer disc mower ? in reply to Ken Macfarlane, 12-14-2004 05:37:37
Shaft: Vermeer, New holland
Gear: Krone, John Deere, Kuhn
Not Sure: New Idea, Hesston
Hay Dr
12-14-2004 08:01:55
 Re: Vermeer disc mower ? in reply to James in NC, 12-14-2004 07:48:07
New Idea & Hesston have shaft driven mowers. Their design is a reworked Lely design just as Vermeer is a Lely design. New Holland has a more complex design that is more expensive but yet is a good design.
ken macfarlane
12-15-2004 06:35:20
 Shaft drive disc mowers ? in reply to Hay Dr, 12-14-2004 08:01:55
What about J-F, Gehl, Vicon, Claas (I think), PZ?
You may not get all these brands down there I suppose.
Hay DR
12-15-2004 14:40:04
 Re: Shaft drive disc mowers ? in reply to ken macfarlane, 12-15-2004 06:35:20
JF- Gear
Vicon,PZ,Taarup-Kverneland (Bush hog) gear
Marangon- Gear
Class- Gear
Fort, Morra, Long, First Choice, Bumble Bee -gear
G&S- Gear
Bellon- Gear
Rhino- Gear
Galfre'- Gear
Fella- Gear & Shaft
Krone- Gear
Kuhn- Gear
Agram- Gear
SIP- Gear
Pottinger- Gear
These are some of the world's magor brands but I can also think of another 10 that are not known by most Americans.
Ken macfarlane
12-16-2004 06:39:38
 Re: Shaft drive disc mowers ? in reply to Hay DR, 12-15-2004 14:40:04
Perfect! We get about half those brands in Canada although many have no dealer or only one dealer. I'll keep my eyes open!
Someone told me the early NH's used Kuhn's gear cutter bar, anyone know about that?
James in NC
12-16-2004 08:06:56
 Re: Shaft drive disc mowers ? in reply to Ken macfarlane, 12-16-2004 06:39:38
I know early JD used a Kuhn cutter bar, not sure about NH.
Hay DR
12-16-2004 15:06:51
 Re: Shaft drive disc mowers ? in reply to James in NC, 12-16-2004 08:06:56
third party image
The older JD & NH models were alike using Kuhn cutterbars. JD 3 point mowers use Kuhn cutterbars but JD mower conditioners use their sectional design, pictured below. NH has used their own designs for at least 6 years. NH has a multi-shaft design.
James in NC
12-15-2004 08:31:54
I believe that Vicon is gears and I have not seen a Gehl in a long time.
