JD 14t square baler
Levi F.
12-06-2004 17:27:27
I"ve got a 14t baler with a wisconsin engine instead of a pto. I was wondering what the horsepower of this two cylinder engine was.
thanks in advance
Bernie in MA
12-08-2004 16:14:57
 Re: JD 14t square baler in reply to Levi F., 12-06-2004 17:27:27
I used to run an engine-driven 14T, now have a 24T with a WI engine.Two years ago I mounted a second engine over the plunger chamber belted to the same flywheel using two double vee belts. No more creeping and stalling in heavy hay. Works excellent. My tractor is a Ford 2N.
RobN
12-06-2004 18:42:09
 Re: JD 14T square baler in reply to Levi F., 12-06-2004 17:27:27
My manual states it's a Model THD rated at 17 hp. 15, 17 - close enough. Given its' age, it's probably closer to 15! HTH.
I Bleed Green
12-06-2004 17:54:40
15 hp
