4ft Woods Brush Mover
Tom H
12-05-2004 06:02:13
I recently bought a Woods rotary cutter. I would like to take the blades off the mower and have them sharpened. When I lifted the mower there was only one bolt that attached the stump jumper (at least that is what I think it is) to the gear box. The blades are attached to the stump jumper and it appears that the only way to remove the blades is to remove the large circular housing (stump jumper) under the mower deck. What would be the best way to go about this? Also, does anyone know where I might be able to find a manual for an old Woods rotary cutter. Thanks for your help in advance.
Tom
Jerry/MT
12-05-2004 16:13:54
 Re: 4ft Woods Brush Mover in reply to Tom H, 12-05-2004 06:02:13
While you're under there, inspect the blades for any cracks, especially around the attaching bolts. If you find any, replace the blades. If cracks propagate far enough and a blade fails, the mower deck won't contain the blade. In fact, it'll come out like a hot knife through butter and can cause serious injury. Be safe!
Dug
12-05-2004 07:45:54
Mark is right. The job is far more difficult when removing the blades, been there, done that!
A 4" angle grinder will work just fine. You don't need a fine edge on the blades.
Make sure the hog is safely supported before going under it, those thangs is heavy!
Dug
txblu
12-05-2004 06:29:28
Get you a $19.95 4" disc grinder from HF tools and do it yourself. I use a floor jack and jack up the rear with it attached to the tractor. Works great. Never tried to get blades off as they are probably frozen due to age and wet environment.
Mark
clodhopper
12-05-2004 18:48:49
 Re: 4ft Woods Brush Mover in reply to txblu, 12-05-2004 06:29:28
There should be an access cover or opening on the deck behind the gearbox (like a 3" opening). This lets you remove the blades by removing a bolt on the crossbar, then there is a slotted plate which holds the pins in place, remove this plate, then drive pins out. All Woods mowers have this type of setup on there blades.
