IH sickle bar mower
tippy
12-05-2004 01:42:49
Trying to find a belt to replace the broken one, have had not luck with napa, anyone have an idea were to buy one
ihkovas
12-05-2004 23:39:51
 Re: IH sickle bar mower in reply to tippy, 12-05-2004 01:42:49
tippy, you didn't say which mower you have,but the 16,24,25-V,27-V,27-VA and 31 used one of two drive belts depending on cycle speed(pulley size). These were the M 32812 for the regular speed and M 32813 for the fast speed. The numbers probably sub to newer numbers at the Case-IH dealer. You can also get these v-belts at JayDee Enterprises at 800-989-0162 or on the web at jdv-belts.com. There numbers are C48 for the M32812 and C50 for the M32813.
tippy
12-05-2004 12:55:06
Thank you will give IH a try, by the way this sickle bar mower only has one belt.
RickB
12-05-2004 04:23:43
Measure the drive sheave. I know there are different drive shaeves for mine, giving different sickle speeds. There may be a belt length change to support the different pulley.
Hugh MacKay
12-05-2004 02:52:24
tippy: On an IH sickle mower go right to CaseIH. depending on dealer you may need to know part number. He can get it.
