You have HORRIBLY confused info from methanol (wood alchol) with ethanol (grain alcohol). Ethanol is a cleaner, it will flush out all the varnish & crud in your old tank & plug up the carb & filters. This does not mean ethanol is bad for your system, it just cleans it out. None the less, you might have to do a carb cleaning.... Ethanol is not corosive. Not at all. It does eat some certain rubber compunds used in the '70s. I'm thinking most old tractors did not use that type, but if so, you would need to convert to a couple different O ring seals. Ethanol does contain less BTU's per gallon, so you will burn more gallons for the same power. Ethanol is more stable, & burns with a simpler flash in the cylinder, so it is a bit more efficient in converting BTUs to hp, but still & all you will use more gallons. You do not need to modify a gasoline engine to run on straight ethanol. Likely if you were designing it for such, you could tweek compression & such to make use of the 110 octaine rating, but they would run extremely close to the same configuration. For the conversion you need to reset the carb, and in cold climates you need a water jacket or a hot air intake to prevent carb icing, as the carb uses a _lot_ more heat to vaporize the fuel. All the racing engines you mention use METHanol, and that is some corrosive, very low BTU, hazzardous stuff. You are right on that. Ethanol is something completely different from what you describe. You have it totally, 95% WRONG. I'm on a tight time line this evening so gotta go, I attended a few seminars & demonstrations of on-farm production & use of straight ETHanol on farms back in the '80s. Pretty good stuff. If you feed livestock, you can make a go of it. They had several tractors running on straight ethanol, and the carb adjustment & anti-icing was about all it took. Oil changes could be extended, because the stuff burns so clean. You are aware most pickups & similar SUV vehicles sold in the USA in the past 5 years are designed to run on multi-fuels, which specifically means E-85??? That is a blend of 15% gasoline, and 85% ethanol. Just pull up to the pump & pump in the E-85. Good to go. Nearly all (95%?) gasoline sold in Minnesota, and other states, is already ethanol enhanced. It is 90% gasoline, 10% ethanol. So you are, or should be, already using some ethanol in your vehicles. There are over 500 retail gas stations in Minnesota selling E-85. I can find a pump 5 miles from my house, and about every 20 - 50 miles I see a station selling it. It is _NOT_ corrosive. Sorry for getting on my soap box, but as a corn farmer living in a state with more ethanol production than any other, I get kinda upset with all the mis-information the oil company puts out on this product. Again, you are about as confused and wrong on this product as one can be..... --->Paul
