Junking a Ford 542 bailer, wheel question.
David A
12-02-2004 07:15:07
Does the 6 lug wheel on the gearbox side have the same bolt patter and center hole size as the ones for Ford tractors. I have a 4610 Ford and was wondering if I need to keep this as a spair, I know it is a 15" wheel but if will bolt up that is all that matters.
Thanks for any help
FordTractorMan
12-02-2004 08:54:32
 Re: Junking a Ford 542 bailer, wheel question. in reply to David A, 12-02-2004 07:15:07
Hey there. Do you have the rubber teeth on your baler? If so, I could sure use them if they're any good and I also need a clutch off of it. Where are you located?
FordTractorMan
12-02-2004 08:41:59
David A
12-02-2004 08:54:50
 Re: Junking a Ford 542 bailer, wheel question. in reply to FordTractorMan, 12-02-2004 08:41:59
It has the rubber teeth and slip clutch. Most of the bailer is there except for the knotters needles and the PTO shaft, it has been taken off at the clutch. Located in North Central AL, Walker Co.
FordTractorMan
12-02-2004 09:24:06
 Re: Junking a Ford 542 bailer, wheel question. in reply to David A, 12-02-2004 08:54:50
Would you mind giving me the city so I can check the distance on MapQuest? How much would you need for the clutch and teeth, or just the whole thing? Thanks.
FTM
David A
12-02-2004 11:00:50
 Re: Junking a Ford 542 bailer, wheel question. in reply to FordTractorMan, 12-02-2004 09:24:06
About 15 min south of Jasper AL, or about 1 hr west of Birmingham AL.
The bailer has been sitting out side for several years since I parted it out to fix another one. There are a lot of good parts on it. I was going to sell it for scrap but if you are intersted I would rather see it go to use.
David A
12-02-2004 11:09:09
 Re: Junking a Ford 542 bailer, wheel question. in reply to David A, 12-02-2004 11:00:50
I would take $50.00 for it to keep from having to load it up and haul it off. I was going to get rid of it Saturday. If you want it let me know when you might be able to get it.
Send me an e-mail if that would work better.
FordTractorMan
12-02-2004 11:04:00
I am interested, just not sure when I can come get it. How much? Salvage around here is currently $60/ton...Thanks.
FTM
David A
12-02-2004 11:11:48
 Re: Junking a Ford 542 bailer, wheel question. in reply to FordTractorMan, 12-02-2004 11:04:00
[email protected]
