Thanks, any Info is helpful. micheal : : Hi, : : I have a 7' sickle mower that i hope someone can give me some info on. : : I got it from a guy who said it was and old ford design. It is a 3-pt mount : : it has a main casting with a channel in it where the cross-draw bar for the 3-pt hitch : : goes into. The 3rd link pins into the top of the casting. The mower is belt-driven with 2 : : 40" v-belts from the Pulley the pto shaft is connected to, to the pulley that the pitman eccentric is on. This mower doesn't : : have any real frame (like a Ford 501 would), it has a 2 1/8" bar that runs too the right from where the casting sits on the drawbar. : : the bar connects this other casting that the sickle bar mounts too and it has the inner shoe on it. The mower also has a smaller rod that runs perpendicular : : to this big bar and I have that running up under the rear axle of my 8N Ford and use it as a 'break away' bar. My problem is: I would like to know how this : : mower is to be mounted on the tractor. The big casting is simple, but if you do not mount the right-hand casting to the drawbar somehow the bar would never lift. : : This right hand casting also appears to be how one would set guard angle, lead and the amount of lift for the bar. I have made a bracket but am sure it is not the : : way it is suppose to be, because i can not get it to cut even (slides over on about first 1 1/2' of the bar and the break away sorta' works. I am sure this should have some : : spings or cables or something but am not sure where or how they should go. If anyone knows anything about this mower, PLEASE let me know what you know. I would be very greatful. : : thank you, very much, in advance. : : micheal : Mike, : I recently aquired two Dearborn sickle bar mowers. : They have the name plates still attached along with S/N. : There is a spring and a cable involved with the mower. : The cable is hoooked on one end to the mower and the : spring on the other. There is an attachment that fits : under the bracket underneath the wheel that is the reset : for the break away. It is adjustable with a odd looking nut that : has a ball and spring inside. When the sickle hits : something solid, the detent ball in the funny looking : nut allows the sickle to retract using the spring and : cable. It re-engage, just back up until it re-engages. : :
